Because you have no air flowing through the radiator when stationary, it will heat up. Thermo fan switches are relatively inexpensive. I am sure CVCC would keep them in stock. Always run the thermostat in the car to, otherwise the cooling system gets confused as to which way to pump the coolant!!!
Cheers, Andrew![]()
