Have you checked the coolant level under the bonnet then?????????????
It's probably right on the limit of a top up and once warm the sensor is submerged.
This morning when i started car got error on dashboard like: coolant error (check manual)..
Comes with one beep...After 5 minuts, i shutdown car and started again - message done...
I done major service 2 weeks before...
Is this something i should worry?
car: passat 2.0 tdi (engine code: cbbb)
