Results 1 to 6 of 6
Thread: Coolant disappearing causing coolant warning. Type 3c TDI dsg 2007
    Help,
    Not sure if I am in the correct area, first real post.
    For the last 6-8 months we have had the coolant warning coming on due to "low" coolant (coolant was low). But no leaks to be found. Have had vehicle back to dealers number of times with no luck in finding "leak". Last week same thing, we had the vehicle back to the dealer where they have replied with:
    "Investigations carried out when the vehicle was booked into the workshop indicated that there was no external coolant loss. The vehicle needs to be stripped and inspected. The possible cause for the coolant warning light is a faulty Exhaust Gas Recirculation (EGR) cooler.
    We will need the vehicle over two days to get the repairs carried out."
    Is this correct? Does coolant go through the EGR and could that be the problem? There is obviously coolant loss as I'm having to refill the bottle everytime the warning goes off (this time 6 weeks after VW filled it). I would appreciate any advice as I'm wondering if they have gone into "guess mode".
    Many thanks in advance.
    Dec 2008
    Sydney/Canberra
    The EGR has it's own cooler, so as to not to melt nearby components, and to promote faster warm-up.
    They will most likely put a pressure tester on, with the EGR removed, but with the coolant hoses still connected. If that's ok, there's always the engine oil cooler, DSG oil cooler, and heater core to test.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2009
    Melbourne Australia
    Loss of Coolant with no apparent leaks usually means it's going out the exhaust. Possibly the Head gasket / cracked /warped head??. Had the same problem before, but not on a VW.
    Good luck, sounds expensive.
    rotelman
    Passat MY09 125TDi DSG Wagon - Arctic Blue
    Tint,Tow,E-Tailgate, Roofbars & Cow,Fog, 12GB SDHC
    VW Bluetooth
    Nov 2009
    North Shore, Sydney, NSW
    Agreed.... Had it happen to a 2005 Holden (Opel) Vectra V6 I once owned. Car was 9 months out of warranty so I got rid of it... Just didn't want to know about it, read; cost of repair........ ;-(
    Quote Originally Posted by rotelman View Post
    rotelman
    * MY12 B7 Passat V6 4-motion Highline wagon....
    * Sport pack (Kansas wheels) - Active cruise City EB - Driver Assist Vis pack - Auto tailgate - Candy White with dark tint.
    Feb 2009
    Same thing happened to my Passat,cylinder head was replaced and it was done under warranty , i hope it's something else with yours, anyway good luck
    Arteon 2018 ,white , Sound and Style Package , Sunroof, APR Stage 1,Turbo Inlet ,K&N
    Well an update after the car had been at the dealers workshop for 3 days they are still none the wiser. So we have been handed back the car ( no charge as yet - very happy about that) to see if the "problem" occurs again....
