Results 1 to 7 of 7
Thread: Comfort Control Module 1999 Passat 1.8T
    Jan 2009
    Central Coast NSW
    Hi Everyone,
    I'm new to the forums as I just bought a used 99 Passat. Unfortunately I failed to notice that the interior lights didn't work. I checked the fuse, and it appears to be fine, so then after scouting about there seems to be a common problem with the Comfort Control Module. Apparently its located under the carpet on the "drivers" side, but does anyone know whether the module stays on the left hand side? Also any tips on the best way to access it would be appreciated and does disconnecting the module cause problems?
    Thanks
    Simon
    Aug 2006
    i'v pulled mine apart and it was under passenger side
    had to rip up the carpet and its just plugs
    Water damage would be pretty common. I had it on a Passat in the UK. I dried it out an stopped the leak.
    Jan 2009
    Central Coast NSW
    Do you know how much it was to fix?
    That's a call you VW to find that out.
    If you can take it out you might be able to clean it out and get it going again.
    Camden, Sydney
    Definately under the passenger seat. I have a passat here I am wrecking with that module, but will need the part number off it.
    Dec 2007
    Girraween
    if the microswitch in the door is playing up the interior light wont come on if that door is open, but will when a different door is open
