Results 1 to 10 of 13
Thread: Coilovers on r36
    Nov 2009
    Strathfield, Sydney
    Coilovers on r36
    Anyone running coilovers in their r36...if so what brand
    Jun 2009
    To be honest, i think the stock suspension is the best setup for the .:R models.
    I don't think anyone has changed to coilovers.
    Nov 2009
    Strathfield, Sydney
    Stock suspension won't get me very low...
    Jun 2009
    Quote Originally Posted by 111 View Post
    The .:R models aren't about getting low and "looking baller"
    You should have gone the CC or a normal passat if you were after that imho.
    The .:R models are about raw NA power and using it.
    Hence the suspension set up that allows power to be utilised most effectively.
    Sep 2009
    You can try the H&R coilovers or the Bilstein PSS9. Quite a few brands you can look at. KW Variants are not too bad too.
    Nov 2008
    Sydney, Macquarie Park
    Quote Originally Posted by sloutch View Post
    pretty much covered all of them up you can also have a look at new bilstein pss10
    '01 VW Bora V6 4motion - gone
    17x8 TSW Hockenheims ~ TyrolSport Brake Upgrade ~ SMF + Stage 1 Clutch ~ 42DD Shifter Linkages ~ FK Coilovers
    I would look at DMS (Drummond Motorsport) coilovers. We sell them along with Bilstein etc but have had the best results with DMS. They are designed for Australian conditions and the 50mm range is brilliant for daily driving, weekend run and track work.
    Jun 2009
    Toowoomba, QLD
    Quote Originally Posted by Evaded Motorsport View Post
    Can you give rough prices?
    Sep 2009
    Quote Originally Posted by okisub View Post
    I reckon they are priced at about the $4,000ish mark. Had a set of DMS when i had a skyline gtr
    Nov 2009
    I have DMS 50mm in my Evo IX - I use it mainly on the track but I do still drive it to and from track days and to work every now and then.
    They are excellent! A much nicer ride than the std Bilsteins that came in the car actually despite having harder spring rates.
    $4300 for Evo IX ones.
