Re: Changing parking lights for LED's
You don't need to remove the headlight. Just remove the headlight cover and reach in from the back of the assembly. It is a little hard to access but you'll need a little patience especially when placing the new ones in as the hole is tight. If I recall correctly one side is easier than the other due to accessibility. Parker's are T10.
I've ordered some canbus bay9s for my front turn signals but yet to arrive. Had to buy 6pcs which was cheaper then I'll sell the balance 4 once I get them working.
Haven't had a chance to replace the static cornering lamps yet.
My interiors were replaced with warm white LEDs which look a lot better than whites.
Update: received my BAY9S leds today
Sent from my GT-I9100 using Tapatalk 2
Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
