I have some very good globes from Ali express. Search for the thread or I'll find and post it later. But you'll need to use red leds as white globes are too bright and look pink through the red plastic housing.
Sent from my HTC One using Tapatalk
How have others gone about changing the bulbs on their B7's to LED?
The main one I'm unsure of is the rear tail/brake light, I notice that these are W21W. When the tail light is on it is dim as a tail light, then goes bright as a brake light - it is not dual filament. Are there any LEDs on the market that will work the same way?
I've searched around but have been unable to find anything. The only thing that is consistent is that the globes need to be CANbus error free.
I couldn't find any globe lists on the internet or in the manual, so here is what I identified by removing all globes:
Rear
Tailgate tail lights W5W x2 each side
Tail/Brake light W21W
Reverse light W18W
Indicator WY21W (orange)
Front
Indicator PY21W (orange with offset pins)
Daytime Running Lights P21W
Fog Lights H8
Look forward to other's experience and advice on what to use.
How do they go handling the different light intensities? I assume this is done by supplying 6 V as a tail light, then 12 V when needed as a brake light.
Probably, never put a multimeter across the terminals. They work is all I care about.
U in melb? Pls pm me as I have done it..
MY14 B7 Wagon 130TDI| Driver assisted and visibility package | Sports package | Panoramic roof | Convenience package (push start button / easy open) | R Line steering wheel | R Line MFA instrument cluster
I'm in Sydney and would love it if someone could point me in the direction of a website to buy all of the above!
Search for my post, I already have the visibility package but replaced the front and rear indicators with LED's the H8's for the driving lights are hard to find.
