Had the same thing go on my R36. O2 sensor was replaced under warranty
Hi all,
A colleague's R36 switched its check engine light on this morning.
Scan showed the following fault:
Address 01: Engine Labels: Redir Fail!
Part No SW: 03H 997 033 K HW: 03H 906 032
Component: P3.2 FSI-EU4 G00 2368
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 16490 959 59785
VCID: 356AD3775C482AB66E3
1 Fault Found:
008756 - Oxygen (Lambda) Sensor B2 S1
P2234 - 004 - Signal Shorted to Heater Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 16
Mileage: 99177 km
Time Indication: 0
Date: 2013.06.08
Time: 16:30:47
Freeze Frame:
RPM: 628 /min
Load: 26.7 %
Speed: 0.0 km/h
Temperature: 75.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.335 V
Readiness: 0000 0000
I presume this might just indicate a faulty lambda sensor and it should be replaced?
yep.. as its the heater circuit...replace the probe mate.. thats the easier one to change aswell...more space on the gearbox side...VDUB...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Thanks for the replies guys.
vdubmotorworx, just as a ballpark figure what would you charge to replace one of these? Just want to make sure he doesn't get too ripped off.
depends on where you go but 30 mins for that probe should be about right as its the easiest of the 4...most places will want to diagnose it before fitting on your request...1hr labour cost I would say depending on where you go would vary on price...back street / dealership....
