Results 1 to 9 of 9
Thread: camber?
    Aug 2006
    camber?
    what ways are there to make your tyres not have inner wear.
    Oct 2005
    Quote Originally Posted by 1DUB2C
    a combination of adjusting:
    - the camber - relativeness of the top of the tyres vs the bottom of tyres - measured by a spirit level against the face of wheel- in an ideal world and even tyre wear world be achieved if tyres were vertical
    - the toe (relativeness of width of tyres at front to the rear); ideally again, equal front and back tracking
    but in reality you are probably looking for little bit of negative camber and a bit of toe in. factory would probably be a little bit of -ve camber (top of wheel further in) and toe in (front of tyres closer together than the rear of front tyres)
    when you get an alignment done at a tyre shop check that they will adjust both camber and toe (not just toe)
    \'95 Golf VR6
    Aug 2006
    so there is a way to adjust my camber and toe? without buying camber kits etc?
    brackie Guest
    Help here
    Look in the "Interseting Articles" forum
    Oct 2005
    toe, yes; camber - i would assume there is on your passat, as it is on all golfs - anyone else know?
    my thinking is that camber kits are for those cars that either a) are not camber-adjustable or b) so excessively dropped that they need extra!
    \'95 Golf VR6
    Aug 2006
    i'm still not sure what i'm supposed to ask for at the tyre shops..
    my fronts are angeled in abit more then the rear.
    syncro Guest
    Go to a reputable steering specialist and get a wheel alignment. Don't go to a tyre service.
    Adams at Padstow.
    Barry Solomon at Mortdale.
    There is a place around Sydenham also.
    Aug 2006
    would u have the address or phone for the barry solamons at mortdale, seems like the closest one to me.
    syncro Guest
    The camber appears to be adjustable on a Golf 3.
    To adjust the camber on a Golf 2, you need special bolts, part number N 101 740 02. These are the standard bolts for Golf 3. If not, C&S Auto has them.
Similar Threads
  1. mk3 - wheel alignment done myself
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 10-01-2007, 09:00 AM
  2. dodgy mods....
    By gldgti in forum Mk1 Golf
    Last Post: 03-01-2007, 10:21 PM
  3. What Camber can you run on a Mk1
    By Golf Loon in forum Wheels & Suspension
    Last Post: 08-12-2006, 05:37 PM
