Results 1 to 4 of 4
Thread: bubbling coolant Sound after stop the car
    Jan 2007
    Raby NSW
    I have a 1998 v6 Passat. I have notice that if I lift the hood after a run that I can hear bubbling sound coming from the coolant bottle area.
    Is this normal or any know symptoms? Thanks
    Oct 2006
    sydney
    normal due to the fact the coolant is stil hot
    brackie Guest
    De-gassing tank
    The correct name for the "coolant bottle" is a de-gassing tank, so the bubbles show that it's doing what it's designed to do. The trick is to recognise an abnormal amount of gas so if you're motor isn't overheating I would sleep well tonight
    midget Guest
    try running around without the aircon on and see if you still have the sound afterwards
