Results 1 to 10 of 13
Thread: Brake Pads
    Jul 2010
    Brake Pads
    Looking for some advice on front brake pads for a 2007 Passat v6. I had the warning light come up on the dash, we've done 46000km.
    Before i head off to VW i wanted to see if people are using a non OEM alternative, and if tehre is a local installer on the North Shore Sydney. Also should i also expect to need new rotors too? Anyone have an appproximate cost?
    Jan 2007
    South Australia
    Quote Originally Posted by SilverWagon View Post
    Maybe try an aftermaket VW specialist if worried about the costs????
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Adelaide hills, SA
    You most likely will need new brake discs, I wouldn't go with the aftermarket b.pads, the saving is just not worth it. You should be able to find independent VW specialist in your area.
    Jun 2012
    We had the pads changed in our Lexus at about 90,000km for a less dusty type (genuine Toyota part). The original pads were as bad as any european car for caking the wheels in brake dust but the new ones were great. Still in there at the 140,000km mark and haven't noticed any degredation in performance or excessive wear of the rotors.
    Do VW have a similar option? The Vicenza wheels are a right pain to keep clean.....
    2017 206 TSi R-Line
    Remsa brake pads from GSL rallysport (a sponsor on here) are a good option for replacement brake pads that wont break the bank and give off far less brake dust.
    There are quite a few people on here (myself included) running these pads.
    Nov 2009
    SEQLD
    +1 for Remsa pads...
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
    Apr 2011
    Also running Remsa pads on the R36, a little less brake dust with a touch more progressive feel.
    Adelaide hills, SA
    Quote Originally Posted by CaseySP View Post
    Yes, ATE Ceramic brake pads. No dust and almost no wear on the brake discs. When I wash the car I don't have to touch the wheels, just use the hi-pressure cleaner on them.
    Jun 2012
    Cool thanks - I'll check them out.
    2017 206 TSi R-Line
    Feb 2008
    Sydney, Australia
    I've been looking to get ATE Ceramic pads as well, but there doesn't seem to be a set made for the current B7 V6 Passat Wagon.
