ATE Ceramic.
You'll need to replace your rotors in all likelihood also, go with ATE solid rotors.
After 150.000 km on original brakes i was told brake need to replaced on my service. I am happy with oem except dust (lot dust)...question what would you suggest for next replacment...i was thinking brembo pads (not expensive- 120$ pair)...
Any better idea or stick on oem?
Regards
Sent from my D6503 using Tapatalk
2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
ATE Ceramic.
Any idea from where i can get it (except ebay) and how much would bi this? Thank you
HSY are the importer but they won't sell direct to plebs. Suggest you ring them and ask who can get them locally to you.
You are a man...thank you. I wil check...
You'll need disc rotors as well. you won't have enough meat on the OEM rotors to machine them properly
Also, have you had a look at the pads yourself? Sometimes the mechs take quite a conservative approach. They probably don't realise that you have got 150k out of them (that you aren't a heavy user of brakes)
No, i am driving like old fartreally, i do not have performance car but diesel. Yes, they show me pads...it is time. Also, they suprised pads used for amost 150k
If i need to change rotors then i will go wit kamold's advice - ate brakes and rotors. Only need to find supplier since hsy not cover individuals but bussiness.
Are you in Melbourne?
B6 Passat Wagon No KESSY
