Results 1 to 6 of 6
Thread: Braided Hose
    Nov 2008
    Bankstown
    Question Braided Hose
    Seeking assistance to identify this braided hose
    1999 passat 1.8t fuel AEB .
    There is a braided hose approx 10mm o/d and 3mm i/d connected to a nipple on the radiator end of the intake manifold. The hose is approx 250mm long and disappears under the intake manifold, then emerges and connects to another nipple on a small cylinderical component approx 30mm dia.
    This hose has broken away from the nipple.
    1) What is this hose ?
    2) what does it do ? ( I am not noticing any change in performance)
    3) Is there any future internal damage concerns whilst driving before hose is repaired?
    4)There appears to be some miserable fancy hose clips, clamping the hose to the nipples. Is there a special tool to crimp the clips.
    5) Is it ackward to gain access under the intake manifold, as the hose appears to comprise of two pieces.
    Once again I thank you for your much valued replies.
    Regards John
    Aug 2006
    r u talking about the line to the stock blow off valve??
    does ur car now flutter?
    Nov 2008
    Bankstown
    Thank you, unfortunately I can not find any specific information on this except ( charcoal filter ??). My knowledge is limited, regretably.
    Nov 2008
    Bankstown
    If I had pulled the curser down a little more I would have seen your wonderful picture. Yes, that is where the line is broken and the braided hose at the rear of the intake manifold is in need of repair also. I am not noticing any fluttering. I recently purchased a VCDS ( to become far more familiar with the car), it did not reveal any faults (assuming the hose was not a recent break).
    Aug 2006
    yeh just replace it with normal rubber hose. it goes down to the stock divertor valve.
    Nov 2008
    Bankstown
    Thumbs up Braided hose identified, thank you
    Thank you for your assistance, the engine is not AEB but APU, as I found out later. I will search for some suitable rubber hose as it gets damned hot under the bonnet.
    Best regards John
