biggest question, has it had the DSG mechatronics unit replaced. if it is still under warranty then it shouldn't be an issue.
Matthew
Hi all
I am currently looking at buying a 2nd hand 2007 TDI DSG Passat.
It has 36k on the clock
Any ideas what i sould be looking out for when buying a car like this?
cheers
MY10 VW TIGUAN White
TDI Auto Sat Nav/ RVC Sun roof Off Rd Comfort Alarm Fogs Tow bar Tint.
TDI -Longivity Performance Reliability
Matthew
2010 MY10.5 R36 Wagon, Biscay Blue, RNS510, Dynaudio, Sunroof, towbar, Dynamic Chassis Control, No lazy back door![]()
2008 Audi Q7 4.2TDI, Radar Cruise, Lane Assist, Blind Spot Assist, Heated Seats Front & Rear, Alcantara Hood Lining, Wooden Gear knob, Nappa Leather, Plus all the usual V8TDI gear, like 760nm of Torque!
drive over some speed humps to see if its got any rattles- they seem to be be a "feature" of these cars.
had a passat tdi. now mb c class.
Check if it has a DPF on it and see if it has been replaced.
Might want to look at a provent or dpf-delete in the near future if you go the TDI line.
Custom code have done a DPF delete pipe and software upgrade for the TDI VAG engine i believe.
Cogdoc is getting his GT TDI done soon.
It removes the DPF and gived you extra power becasue the DPF is the most restrictive part of the system.
It also saves you money as the DPF will not clog up (since it isn't there) and cost $5k to replace.
the provent system acts to prevent a lot of the EGR buildup in the DPF.
This prolongs the life of the DPF but the Delete option is permanent and gives much more power and torque.
It is legal.
The DPF is put on to allow the cars to be Euro V compliant.
New cars have to be compliant with euro emissions standards to be sold.
One it is sold, they no longer need to be compliant and as such you can remove the DPF.
Perfectly legal to remove it and you get power gains in teh golf of around 50kw and smoother torque delivery.
AFIK the MY07 TDI only offered the 103KW motor which did not have a DPF.
The MY08 TDI offered 103KW and 125KW motors and the DPF was only fitted to the 125KW motor (with 18 inch wheels as part of the option package).
Of course, others on this forum may have more knowledge about this than I do.
Andrew
MY07 TDI Passat
