Results 11 to 20 of 22
Thread: Best Fuel Consumption for 103/125kw TDi's on longish trips
    Melbourne's NE
    Sorry, vanDub,
    Going off-topic yet again !
    The LHS rattle is, at least in my case, a rattle coming from the area where the sunglasses compartment is. 1500 rpm will set that off without fail which is annoying since (provided there's no major load on the engine) you can cruise at that rpm for best fuel economy (back on topic).
    It seems slightly temperature-dependent, and might be restricted to people with a sun roof (extrapolated from the signatures of the posts above).
    Anyway, over 14000 kms I'm just under 7l/100 km, and just like vanDub (and probably everyone else) I'm not holding back all that much, cruising at the speed limit, enjoying the rolling acceleration. Run down to Geelong last Friday yielded 5.4 there, and back, according to the MFD which, in real life, is about 5.8-5.9. One has to be happy with that.
    Seeya,
    Michael
    MY08 125 kW TDI Wagon
    PE Black, Sunroof, iPod
    MY09 CR TDI Eos 6-speed manual
    Candy White, black leather, Sports suspension with 18" Chicagos
    Bayswater - NO the one in Perth! :-)
    Quote Originally Posted by Deep Black View Post
    Can some one teach me the trick to show speed on climate control display?
    BTW my new Passat 125KW TDI has the LHS-dash rattle problem as well. It looks the fitting quality is not up to general German standard. Rattle seems quite common in the Passat range.
    See your PMs....
    2011 Midnight Blue TDi Highline wagon del Aug 2011, and 2014 Touareg 4XMotion in Graciosa Brown
    Mar 2008
    North Lake WA
    Wink
    Quote Originally Posted by drbass View Post
    May be something in the sunroof theory...mine doesn't and is completely rattle free.
    I will reiterate others and say the 125kW diesel is so drivable with all that lovely torque and then you get all that range, because who really likes standing by the pump at the servo!
    Interestingly read a review of a 3.3l V6 Lexus RX330 petrol which only had 3kW extra power than the TDI. This was an alternative for me, and as its petrol I doubt it had similar torque, so I'm glad I went VW diesel.
    WestOiler125
    MY13 Passat Alltrack
    125kW 2.0L TDi DSG
    Thumbs up consumption
    Picked up mine on 28June. I've done 3300km, almost exclusively around town and on the freeways in town.
    The last leasing company monthly printout based on the kms entered at filling and the litres used gave a monthly average of 7.3 l/100km.
    I am loving the torque, and making sure that I am throwing it into S and flooring it... ummm... if my wife is reading this, using the full rev range of the engine , once every few days when the car is nice and warm. The rest of the time I think I am probably a little heavier than I should be on the fast pedal which might explain the slightly higher consumption that a few posts have already mentioned.
    So far not a drop of oil used and never a puff of smoke from the rear (checked at night when it is more obvious as well). Love it!!
    Just that little rattle I have to get to... (BTW mine is NOT from the sunglass holder area - it is definitely from around the LHS of the glovebox.)
    Melbourne's NE
    Time to bump this one.
    Done 20,000 now. Average is just under 7l/100km. That's mostly short-ish commuting (8-15km) with the occasional longer run. Not really driving for economy, either.
    I'm most impressed, even more so after today's trip to Horsham and back. Computer is giving me 5.4/100 for the tank (700 km, just under half full) and 5/100 for the return trip. At one stage (coming down the hill at Bacchus March) I had done 620 km, and the computer gave me another 790 to empty. Optimistic, but nontheless impressive (in a geeky sort of way).
    As mentioned before, my computer read-outs are generally about 10% optimistic.
    All things considered, I'm very happy with the car in general - it's been terrific. Only negative is the DSG behaviour from standstill, and when reversing (discussed elsewhere) - of course it's "the best" once you're moving.
    Anyway, that's just me. However, we're looking at buying an EOS now as well, manual Diesel, most likely.
    Seeya,
    Michael
    Sep 2008
    I drove from Melbourne to Newcastle last Sunday, sitting on 120 (speedo) with the air-con on most of the way. I filled up when I arrived in Newcastle, a tank distance of 1045km and consumption of 60.04 litres (average of 5.75l/100km). It was only because I had to go back to Sydney on Monday that I refuelled, but looking at the numbers now I easily would have made that, so could have achieved around 1200km (+/- 20km) on the tank - at that consumption rate, it would have used 69 litres, plus the southbound trip into Sydney is marginally easier on consumption than the northbound.
    Since then, with another couple of trips around Sydney and the Blue Mountains, according to the car I've travelled around 1500km and used 5.8l/100km average.
    Cumulative average for it since I picked it up (as at last fill up): 277.54 litres and 4,177km, an average of 6.64l/100km, with a reasonable mix of around town Melbourne/Sydney/Geelong/Newcastle, freeways and highway driving, flat ground and mountains. I've also not been too light on the throttle and taken full advantage of its performance a few times, as some Falcodores have found out to their chagrin.
    In Melbourne, from out north west (near Sunbury) to Altona, Werribee and Geelong I regularly get around 5.1 on the way there, and about 5.6 on the way back (the hills around Melton Hwy past Calder Park really throw it out).
    I'll be heading back to Melbourne from Newcastle tomorrow - not sure whether to stick on 110 indicated to save a bit on fuel, or stay on 120 and do the trip that bit faster. It'll probably be the faster one.. I need to get to work on Monday and won't be able to leave Newcastle until about 10am..
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
    Feb 2008
    Outer East - Melbourne
    my TDI 125kw is getting a long term average of 7.47 lt/100km based on 16K of mostly city driving.... calculated based on actual fuel into car over 9 months. My best "displayed" value has been 5.8 lt/100km on a Casltemaine run IIRC.
    I am concerned about the apparent inaccuracy of the speedo! I usually "stick" to the limit or maybe a couple km over... is the lame speedo the reason why so many behind me seem to get pissed off at me driving at "100" in a 100 zone?
    MY12 Volvo V60 T5 Tekink in Ice White
    MY08 125Kw TDI DSG Wagon in Mocca (02/08 - 03/12)
    Melbourne's NE
    Hi passatpout,
    Were you on Motor Torque last Thursday night?
    The odometer in my car is spot-on (measured a few times using km markers along various highways/freeways).
    HOWEVER, the speedo is definitely out. According to my GPS (Garmin Nuvi), at 107 speedo (set via cruise control) I'm actually sitting on 102. 117 on the speedo correlate to 111 real life. So, richdave, you're probaby doing only around 95 when your speedo indicates 100.
    Best real-life tank (filled to the brim) gave me 5.9l/100 (computer gave me 5.6), 66.6l for a total of 1129 km (incl. Melb-Syd via Gippsland/Canberra, some Sydney driving, then down the coast to Woonona). I find that the computer is more accurate when doing longer trips, and gets worse when there's many short trips - about 10% optimistic is what it's been up to.
    Seeya,
    Michael
    Adelaide hills, SA
    Quote Originally Posted by richdave View Post
    Their speedo would be mostly similar to yours but they knowingly drive 10km over speed limit and hoping they get away with it. They expect that everybody else will be doing the same and if not they are pissed off.
    Inbuilt inaccuracy in VW cars is actually favor which is saving normal motorist a lot of money since it is easy to go 10km over the speed limit and takes only a split second to get clocked by speed camera.
    I used my GPS to check what the difference was:
    Golf 67km/h GPS measured 60km/h
    T5 64kmh GPS 60km/h
    Touareg 62km/h GPS 60km/h
    The reason for that inaccuracy is difference in tyre diameter (brand new/almost worn out)
    Sep 2008
    Hi passatpout,
    Nope, never heard of it.
    Mine was about 100-150m short over the 5km odo distances marked out in NSW. Bit hard to tell exactly, with a digital trip meter and the position of the sign.
    Interestingly, I went under 3 NSW speed warning signs today. The first was in a 90km/h zone, and the cruise was set at 95 - no warning for me, yet people who were moving marginally faster were getting it. The other 2 were both in 100km/h zones, with cruise set on 110km/h exactly, and no warning for me (the first time round, it flashed up the warning for a white van which then proceeded to tailgate me).
    Seeya,
    Michael
    I've noticed that tank-to-tank, the car figures and the actuals are pretty close - for this trip, the car was saying 5.8l/100km when I filled up in Newcastle, and the spreadsheet I'm tracking the numbers by worked it out to be 5.75km.
    This has me wondering though. From what I've read, we all pretty much agree that speedos seem to be out by about 6-8% (not quite enough to complain about ADR compliance, etc), but we have differing accounts about the accuracy of other info from the car - consumption figures, odos, etc.
    Now to get the joy of driving back to Melbourne from Newcastle tomorrow, into this almost-cyclone that's parked itself over the eastern states..
    Cheers,
    AP
