Results 1 to 3 of 3
Thread: Battery draining overnight
    Aug 2011
    Box Hill, Vic
    Hi,
    Has anyone experienced this with their Passat before? I have a 2006 TDI 105kW Passat Wagon. Had a new Varta N22 battery fitted 18 months ago and now find the battery drains overnight.
    I charged it overnight the next evening, then drove it during the following day - no probs. Then left it overnight and next morning it was flat again.
    There are no obvious cabin lights on or otherwise as far as I can tell. Either the battery must be faulty or there is a short somewhere in the wiring. Any ideas for efficient diagnosis?
    Can I disconnect this battery overnight without causing problems to the electronic management system in the vehicle?
    Any assistance appreciated.
    Cheers,
    FG
    Mar 2013
    Brisbane QLD
    Disconnecting the battery every night would be a pain, be better to get it fixed... possible its the battery itself but more than likely something draining the system.. Have you any upgrades / accessories fitted that were not standard from factory?? Some times a VCDS scan can point to a control unit not going to sleep like the convienence system, other than that a good old battery current draw test will need to be done..VDUB
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Aug 2007
    I know that there were battery drain issues with certain firmwares and rns. did you happen to update the rns firmware, that is if you have one?
