Results 1 to 6 of 6
Thread: B7 Passat sedan boot
    Sydney,NSW
    Hi guys
    It takes everyone that closes the boot twice to shut. Is there a way on adjusting it so it closes in one go?
    Pls help. Thanks
    Apr 2011
    Mine easily closes on the first attempt. Might be an alignment issue with the latch. I have a different problem where the boot lid is starting to open slowly, sometimes not even coming up at all depending on the angle the car is parked. Is the boot lid held up by shocks?
    Sydney,NSW
    Thanks. Yes mine has a shock which went open it goes all the way up regardless of angle. I might check out the latch
    Nov 2009
    North Shore, Sydney, NSW
    Doesn't the boot lid of the B7 sedans use arms (possibly spring operated) & not shock absorbing type arms that are used in the wagons..?
    Quote Originally Posted by R36 DSG View Post
    Quote Originally Posted by cru22z View Post
    * MY12 B7 Passat V6 4-motion Highline wagon....
    * Sport pack (Kansas wheels) - Active cruise City EB - Driver Assist Vis pack - Auto tailgate - Candy White with dark tint.
    Sydney,NSW
    You might be right Riker I can't see any shocks just the arm which probably has springs in them. I might take back the car to the dealership to get it checked out. Thanks
    Penguin, TAS
    I've had the boot lining out before and I'm pretty sure I remember seeing a spring loaded mechanism of sorts, if that helps.
    2017 VW Tiguan 140TDI Highline
    2012 VW Touareg V6 TDI
    1985 Mercedes-Benz 380SE
