Originally Posted by
vw50
Hello All:
An issue has developed with my '07 103kw Passat TDI, in that at times, there is a distinct hesitation when starting off from a stop. It may require, the accelerator pedal to almost go to the floor before there is any movement-then the turbo kicks in at a rush.
It does not occur all the time. It may be on a hill or level road. I've had the car back to the dealer, checked it out, and all was ok. The service staffer went with me on a hill and he got the car to do the same thing. He said something about the dsg and the engine, but assured me there was no problem as it's a diesel.
Having been caught in a traffic situation, I needed the car to move there and then. Having this occur is not the best thing. I use BP diesel (51 cetane rating).
There are no other problems. Fuel consumtion is great.
Has any member got any ideas please.
VW50.
This sounds similar to what I experienced when I first got my Jetta. Found myself stuck (repeatedly) in the middle of an intersection with traffic bearing down and no response from the throttle whatsoever. I was used to using left foot braking technique and have found that not doing that rectifies the problem.
Using the brake disconnects the throttle and there seems to be a time lag between taking the foot off the brake and the throttle responding. It's a pretty ordinary thing to experience and I find the whole thing annoying in the extreme.
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
