Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: B6 Passat 103kW TDI - hesitation
    Jun 2007
    sydney nsw
    Hello All:
    An issue has developed with my '07 103kw Passat TDI, in that at times, there is a distinct hesitation when starting off from a stop. It may require, the accelerator pedal to almost go to the floor before there is any movement-then the turbo kicks in at a rush.
    It does not occur all the time. It may be on a hill or level road. I've had the car back to the dealer, checked it out, and all was ok. The service staffer went with me on a hill and he got the car to do the same thing. He said something about the dsg and the engine, but assured me there was no problem as it's a diesel.
    Having been caught in a traffic situation, I needed the car to move there and then. Having this occur is not the best thing. I use BP diesel (51 cetane rating).
    There are no other problems. Fuel consumtion is great.
    Has any member got any ideas please.
    VW50.
    Aug 2006
    Skye, Victoria
    DSG? I have the same problem in our V6..... VWA assures me this is normal, i cant wait for their tech to drive it...
    In the states there was a TSB (technical service Bulliten) for this, the short code was OJ12.
    Ours is booked in for the 16th Nov, i'll let you know how it goes.
    Jun 2007
    Quote Originally Posted by vw50 View Post
    Hello All:
    VW50.
    This sounds similar to what I experienced when I first got my Jetta. Found myself stuck (repeatedly) in the middle of an intersection with traffic bearing down and no response from the throttle whatsoever. I was used to using left foot braking technique and have found that not doing that rectifies the problem.
    Using the brake disconnects the throttle and there seems to be a time lag between taking the foot off the brake and the throttle responding. It's a pretty ordinary thing to experience and I find the whole thing annoying in the extreme.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Adelaide hills, SA
    Quote Originally Posted by VW Convert View Post
    George
    Yes, the same on our Golf - I just perfected using left foot for braking (timing and synchronisation between left and right-just think about it when you brake, that's all is needed).
    However if you drive only with one foot it is going to be something else.
    Jun 2007
    Chatswood, Sydney
    i drive with one foot and i have the same thing (am currently driving a 103kw dsg golf tdi). ive come to the conclusion that its normal based on the research ive done. basically i guess the engine has no grunt before the turbo hits and so the dsg transmission "slips" the clutch to keep engine revs up but that obviously reduces throttle power.
    its annoying i agree and sometimes very scary when you're just sitting in the middle of a big intersection and then suddenly the turbo hits and your wheels start spinning and you look like an ass lol.
    cant wait for the MANUAL gt sport coming my way mid next month booyah
    tbh i think its just something you're going to have to live with unfortunately.
    -michael.
    ps: all my above comments on whats going on are pure speculation, not based on any real facts
    New user account: Mischa
    Have: gt sport tdi, mk2 gti, mk1 3dr
    Jun 2007
    sydney nsw
    Thank you all for your info. Did a search on the net and in the USA, owners had similar probelms not only with diesels but also the petrol versions.
    With that code info, owners had the software re-programmed, and from the comments, all was ok. No throttle hesitation, quick response acceleration.
    I have sent a complaint e mail to VW A, stating the USA problems and here. They are looking into it, and according to them, they have not received any complaints re this issue.
    vw50.
    Jun 2007
    sydney nsw
    thanks for that code info. have looked it up on the net. probs in the USA, but fixed.
    vw50
    Jun 2007
    sydney nsw
    Just an update. Received info from VW A. There is no 'fix' in Aust for this issue, and again they stated they have not had any complaints. About those codes, they were used for VW's in the USA, and arn't appicable to VW's in Aust. VW's in the USA are different to VW's here----for some reason. The only suggestion was to take it back to the dealer for another look. They did look at the fault codes, but nothing showed up and the car was 'normal'.
    VW50.
    Jun 2007
    sydney nsw
    throttle response
    Quote Originally Posted by BlackVr6ix View Post
    Hello blackVr6ix:
    did you get that problem fix? What was the result? What did they say?
    vw50.
    Jun 2007
    Chatswood, Sydney
    mine is in for service on tuesday, i will definitely mention it and report back
