Results 1 to 3 of 3
Thread: B5 passat issue please help
    Fuel pump. Fuel filter. ??
    Replace the fuel filter in case it is old and blocked with dirt. Check the fuel pump is operating correctly.
    Id start with those items and then work from there onto spark, maf sensor etc if that does not fix the issue.
    Jul 2005
    Have you had a flat battery? These Passats usually needed a throttlebody alignment after a battery change.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
