Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Auto hold - DSG - burning clutch?
    Mar 2013
    Hoping someone is in the know...
    Here's the scenario. Start stop is on and auto hold is on. Sitting at the lights, after taking your foot off the brake, the engine starts again but auto hold prevents the car from moving forward. In this scenario, I understand the brake is held but is the clutch burning ready to take off or is it sitting in nutral? Currently I avoid having the car stationary with the auto hold function on fearful of burning the clutch.
    2013 Passat Alltrack, Black, Pano Roof
    Pacific Paradise QLD
    Quote Originally Posted by AllBlack View Post
    Far better to use stop start and keep your foot hard on the brake till just before the lights change then lift a bit for the engine to start just as they change and off you go Dont bang your foot straight on the loud pedal or you will next be growling about rough starts. Give it a sec to fire up properly. Its just a matter of getting used to it and learning to anticipate a bit
    As you have found out foot braking and auto hold are rather different and the stop start and auto hold dont go together.
    I NEVER use it possibly because there are no hills where i live.
    Mar 2013
    Thanks Hillbilly. Reason I ask is that it applies to me when I'm approaching the lights and I know they are about to turn green but I'll be stationary for 4 seconds so don't really want the engine to turn off. I come to a stop but remove my foot from the brake to keep the engine running. Hence, could be burning clutch.
    Feb 2013
    Wollongong NSW
    You can turn off start/stop. Also braking with light pressure stops the start/stop engaging.
    Fairly certain that auto hold does not ride the clutch. I believe it holds car until you apply the accelerator, when forward momentum is applied via the accelerator, that is the force which disengages the auto hold.
    2013 Passat tdi 130kw/380nm - Autumn Brown, Driver Assistance & Visibility Package, 12 way Power Seats, Adaptive Cruise Control, RVC, Auto Tailgate, Black Nappa.
    Full Nanolex paint, glass and wheel protection.
    As Toto said just dont put the brake on so hard and the engine wont stop but will still hold you still The Stop Start can only be turned off during each journey but Hold can be turned off permanently.
    You can drift up to the lights with the brakes on but not hard enough to stop the engine and car wont move.
    You will learn by experimenting. Same when you have the handbrake on You just accelerate gently and it automatically releases or havent you found that out yet will only do it with drivers seatbelt fastened. Dont think clutch engages till revs build a bit
    Penguin, TAS
    As far as I know, when auto hold is engaged the car uses light brake pressure to keep you from inching forward. So you would think the transmission would be in neutral.... There shouldn't be any need for it to be riding the clutch as it can release it fairly quickly anyway...
    Also, after a certain amount of time 'auto holding', the electric park brake takes over and engages itself.
    2017 VW Tiguan 140TDI Highline
    2012 VW Touareg V6 TDI
    1985 Mercedes-Benz 380SE
    Quote Originally Posted by Lindsay View Post
    My understanding is that it applies the handbrake and releases it as you put your foot on the accelerator . The handbrake light does not come on however
    The clutches are operated electrically by solenoids so are fairly instant in their uptake. I have sat talking with my foot on the brake for 10 mins and have no hot smells but then the Passat has wet clutches so is more amenable to that. The 7sp Dry clutches are the problem for heat.
    Sep 2009
    sydney
    the auto hold isn't using the handbrake, I think, because you can hear the handbrake motor it takes a long time to apply and a long time to un-apply the brake, this is something you do not hear with auto-hold. I would bet it uses the ABS system to hold the brakes on, and no it doesn't ride the clutch.
    Quote Originally Posted by nyc863 View Post
    You actually are correct See this page
    Auto Hold Function < Technical Glossary < Innovation & Technology < Volkswagen International Slight difference in that in the Passat it can be turned on all the time????
    Im sure a good read of this page by new owners will save a list of questions about the vehicle
    Perhaps the admin may like to make a sticky out of it as it describes all the different functions of the vehicles Probably better than the cars manual
    http://en.volkswagen.com/en/innovati...-glossary.html HOME PAGE FOR IT
    May 2010
    Melbourne, VIC
    To my knowledge, when stationary, with the selector in any position other than P or N, on the brakes or with the handbrake engaged, the gearbox has first gear (or reverse gear) selected, and the clutches are disengaged. The clutches engage when you use the accelerator, or motion is detected.
    You can test this for yourself. Disable stop/start and autohold, stop on an incline. When you release the brakes, you'll feel the car roll backwards for a fraction of a second before the clutches engage and slow or stop the rollback. The effect can be disconcerting if you're not expecting it, especially when reversing, but you can mitigate the effect with auto-hold.
