Yeah hand brake on 1 side!!!!!!!!!!!!!
Every thing was going/running well on the Little Beastie till yesterday when a metal on metal grinding noise started coming from the LHR wheel!!!!!!!!!!!!. The handbrake works fine so it must be the drums. Getting Michael at CVWC at Tuggers to check it out next Thursday.
Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
Alba European
I think so too. I was playing around with pulling the handbrake on and off at low speeds and the grinding noise ceased when I pulled it up when it was under load. I am not confident enough to fiddle with removing the drum housing so I will leave it with Michael at CVWC to check it out. Thanks for your input gents.
wheel bearing highly likely
Other than that is the new motor ok???![]()
The new SEAT 1.8 is magic. Had a few teething problems, needing to replace old and perished bits and pieces that we did not change when we put the engine in.
I also Put in bosch 4 pin spark plugs and a decent set of leads, which has made a huge difference. Cant wait for Carbie and Exhaust.![]()
Sure does! Michael at CVWC in Tuggeranong reckons it is a real goer. As I said before can't wait for the 32/36 carbie and the sports exhaust.
