Coil or points, or both mate.
When it was raining it was stalling, now it is stalling all the time my patience is really running out!
Old Skool Passat Power Rules!!!
1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
Crack in the dis cap or yeah the coil spray it all with WD40 and try it. Not too much aroun the cap ive seen a flame there before LOL. Water finds the flaws mate, electricity will take the easy way out and water is an awesome conductor.
Alba European
I am also going to give the carbie mixture a tweek, Thanks for the ideas guys keep them coming, cause the Little Beastie is really trying my patience!!!!!!!!!!!!!
By removing the aircleaner yyou can access the idle jet. Its a small 8m/m headed with a screwdriver slot in it part going into the carby on the rocker cover side from memory. Remove it carefully and give it a good blow out with your mouth. There is a tiny hole on the end that quite often gets the tiniest bit of rubbish in there. Also disconnect the wire to the large electo shut off jet and make sure it clicks.
All this is if you are running the standard carby of course!!!!
We are here to help you as much as we can mate. Just let us know what fixes it in the end, eh??
Andrew
