Results 1 to 10 of 19
Thread: Arrrgghhhh plus1
    Mar 2006
    Canberra
    Angry Arrrgghhhh plus1
    When it was raining it was stalling, now it is stalling all the time my patience is really running out!
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Camden, Sydney
    Coil or points, or both mate.
    Aug 2007
    Crack in the dis cap or yeah the coil spray it all with WD40 and try it. Not too much aroun the cap ive seen a flame there before LOL. Water finds the flaws mate, electricity will take the easy way out and water is an awesome conductor.
    Alba European
    Mar 2006
    Canberra
    Leads are new
    Bad plug leads?
    Mar 2006
    Canberra
    Red face
    Matt, I need to know what to put in it SEAT or Passat?
    Mar 2006
    Canberra
    Red face
    Gave that a try, should I take the dizzy cap off a spray in there?
    Quote Originally Posted by Jimmymac View Post
    Mar 2006
    Canberra
    Angry
    I am also going to give the carbie mixture a tweek, Thanks for the ideas guys keep them coming, cause the Little Beastie is really trying my patience!!!!!!!!!!!!!
    Apr 2006
    Hobart,Tas
    By removing the aircleaner yyou can access the idle jet. Its a small 8m/m headed with a screwdriver slot in it part going into the carby on the rocker cover side from memory. Remove it carefully and give it a good blow out with your mouth. There is a tiny hole on the end that quite often gets the tiniest bit of rubbish in there. Also disconnect the wire to the large electo shut off jet and make sure it clicks.
    All this is if you are running the standard carby of course!!!!
    We are here to help you as much as we can mate. Just let us know what fixes it in the end, eh??
    Andrew
    Mar 2006
    Canberra
    Smile
    I just adjusted the idle mixture and the air mixture screw. It seems to be idling Ok at the moment but I need to take for a drive. Will let you all know how it goes. I just waiting for a phone call and tracking a storm on the Bureau of Mets site.
    Quote Originally Posted by gtimk5 View Post
    Andrew
