Ours are the Euro lights so there is no modding to be done just need to plug in VAG COM!
2009 Volkswagen R36 Wagon
1968 Audi F103 75L Coupe
1966 Volkswagen Beetle Deluxe
Success!for the donuts anyway, couldn't figure out the reverse light setting Greg was talking about.
Though not following the instruction on the first page. I found that with OZ Passats (my car) it's the following (from a later post)
09-Cent Elect
CODING-07
LONG CODING HELPER
BYTE 09 (Center of Tails).
Normal = HEX 0A.
Set BYTE 09 to HEX 00
(to set the byte I copied the whole string in coding-07 dialog and pasted into new value with byte 09 changed.)
DO IT!
Done.
p.s. How do you attach a pic that's not from a URL?
I'm a bit concerned though as reply #94 on page 3, network crasher posted that after this mod, his Euro lights both went dead after 6 months. I not sure if it has to do with this mod or his lights but I wouldn't think that turning the center OFF will shorten the life of the LED light. If anything, it should increases the life, no? mmmm
2008 Passat 3.2 Wagon |
2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
You gotta upload to a photo sharing website eg. Imageshack.
Then post the link here.
Can't wait to see how it'd look like with + w/o braking. Does the inner center light turn on when break pedal pressed?
Current: | MY09 R36 | Dynaudio | RNS510 SatNav |
Ah bugger, got to open an account with a site now, don't have one :-P
Braking lights up the center. Indicator no center.
Posted using Tapatalk
Imageshack is free to use..no registration reqd.
Good for the odd image for web use.
Ah didn't know that![]()
anyway, it's here
ImageShack® - Online Photo and Video Hosting
Pete
MY13 Octavia vRS TDI DSG
certainly does look better imo.
Thanks Pana![]()
Will look even better on an R36![]()
