Results 1 to 10 of 14
Thread: Anyone knowledgeable with Bi Xenon's? Need help R36
    Unkonwn_User Guest
    Question Anyone knowledgeable with Bi Xenon's? Need help R36
    Hi guys, I have decided I will be working on a project to retrofit factory Bi Xenon's to my B6 Passat.
    I have purchased the factory Bi Xenon housings for this project, these did not come with Ballasts. I splurged on new housings to ensure the light cut off etc will be acceptable (no blinding). I am also in the process of investigating the washing function to have this fitted as well (I have micro scratches on the windscreen and I'm sick of getting blinded).
    My question is: I have a wrecked Bi Xenon housing from an R36 Passat. This has what appears to be two ballasts??? Can anyone shed light on this? Are they both acting as ballasts for the Xenons or is one of the silver boxes for a different function (cornering lights etc).
    Does anyone have a bit more technical information on the factory bi xenon setup of an R36 Passat that can share some wisdom?
    I have searched and found some useful threads but unfortunately the photos of them are no longer appearing losing much of their value. I plan on doing a nice write up for this to add value back into the various forums that help.
    Thanks again.
    Unkonwn_User Guest
    Pictures can be provided if i'm not making sense
    Sep 2014
    Greenslopes, QLD
    By all means, take pictures and post them. I'm happy to take a few photos of the Xenon's in my R36 if that helps.
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
    Aug 2007
    You will need the ballasts, afs controllers possiblity. bi xenon control module, headlight washers, new front bar, self mechanicals mounted down the back etc to become legal.
    Unkonwn_User Guest
    Quote Originally Posted by booba View Post
    Cheers for your reply. I don't believe I will need a new front bar for this..
    I am however interested in the function of the "Bi Xenon Control Module" as its not something I have come across yet in my research. This might explain the function of the second 'ballast' looking silver module attached to the headlights. I will post pictures of this shortly
    Pacific Paradise QLD
    Quote Originally Posted by g0harvey View Post
    You will to put washers in which are needed to make them legal despite what all the ones in the aftermarket crap thread have or have not done.
    Aug 2007
    You will need a new front bar and associated washers etc to be legal.
    Unkonwn_User Guest
    Thanks for your response.
    I won't start the legality discussion in this thread as it has been discussed many times and I am well aware of what is required from a legality point of view. Hence why I have payed for brand new Bi Xenon housings to start this project right as opposed to running aftermarket in halogen projectors. The plan is using VAGCOM to enable Bi Xenon with shutter and disable AFS / cornering as the initial install, and work my way up from there as I acquire parts.
    Anyone who has actually done some work with OEM Bi Xenon housings + Ballasts please chime in..
    The specific reason behind this thread is to gather further information on enabling basic functionality of the Bi Xenon unit used in Passats. More specifically - identifying the two modules attached to the lights themselves seen in the pictures below (are both the items pictures 'ballasts'? if not what is the function of the other). I greatly appreciate responses that can add value to this.
    Are these two modules the ballast? Or is one the ballast and the other some other function (please see pictures)
    Jul 2013
    Hills District
    not sure whats behind the the cover in Pic3
    basically everything is behind the cover in Pic2
    Jul 2013
    Hills District
    there is only one ballast which is behind the cover in Pic2
