Results 1 to 9 of 9
Thread: Android Phone and Alltrack
    Mar 2013
    Montrose, Tasmania
    Does anyone have an android phone and an alltrack? I can pair the phone, make calls, check phonebooks ect. It also streams audio via bluetooth but doesn't show any track info like name, time remaining. All this was present with an Iphone 4S but isn't now using an android phone on 4.2.2.
    What phone exactly? Some do and some don't support it.
    HTC phones for example prior to the HTC One do not support AVRCP 1.3 which is required to support transmitting track/title info.
    HTC use a proprietry Bluetooth stack for whatever reason.
    (At least the HTC One now supports it.)
    Apr 2011
    My S3 does everything you've just described (no detailed track info). I'm still on 4.1.2.
    It's not a function of the Android version, but the bt stack which is supplied by the manufacturer.
    Sent from my HTC One using Tapatalk
    Jan 2013
    I changed my bluetooth from 2w7 to 9w7 premium and since then i got all features including track name etc
    Sent from my GT-I9305 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Mar 2013
    Montrose, Tasmania
    Thanks for the replies so far. I have an oppo find 5 which has a snap dragon quad core processor so it is very similar to the samsungs.
    Sait 70, could you elaborate a bit more on your solution. I'm not sure what you are referring too?
    According to this post Opp use AVRCP v1.0 so no track info.
    Changing your bluetooth module in the car will therefor have no effect.
    You'd need to petition Oppo to release a firmware update that updates their BT stack to support the newer AVRCP v1.4 protocol, or hope some developer on xda-developer forums has ported the stack from another device like the Galaxy Note...
    Apr 2011
    Quote Originally Posted by Eaglehawk View Post
    Sorry, I should clarify that it doesn't read the ID information, but it does display the folder the song is in, and the filename. Good enough for me.
    Mar 2013
    Montrose, Tasmania
    Change to a custom rom and all track info showing now. Thanks for all the suggestions.
