Larger tyres may be illegal as there are limits as to increasing diameter beyond a certain limit.
Apart from altering your speedo it will also up the gearing so that it would be slower off the mark and change down earlier on hills.
Alltrack is a bit of a misnomer I would refer to it as a softroader rather than an offroader.
It is after all only an ordinary unitary bodied wagon with different suspension and AWD.
Mine gave an ominous creak going over an badly angled driveway so wont be trying any offroad tracks with it,
Put light things on the roof, not heavy things as that raises the COG and therefore stability.
Also not always the easiest to get off in some situations.
My Cruiser wheels were to heavy for me to lift that high at 44kg If towing remember your ball weight is part of your load and so reduces the amount of gear you can load in the vehicle.
Eg the Cruiser could hold 662kg payload but after 300KG ballweight 130kg fuel, me and wife 150kg only left 82kg for gear.
Whilst your weights will be less the same scenario applies
