Aftermarket Hid
hi, is anyone have got their passat B6 fitted with the aftermarket hid?,
because i had installed the aftermarket one, and there is a blinking problem with it, can someone help me?
thanks
I got the same problem too...
the guys changed the ballast for me to philips brand from unknown brand since than no other blinking or problem.
It was happening to me . It was blinking and turn off by itself before when still on unknown brand of ballast.
Maybe it need to be set via vagcom about HID....
Thanks
origin
so you change the ballats using philips one?,
how much is it?, and where you change it?
thank you
Hi ,
I bought the stuff off e-bay...
Very very cheap...
I sent email to the guy.. I explained it the situation...
He told me to send it back the ballast... and he sent me back...
is your headlight flickering?
oh, ic2.
i also bought the chinese brand one,
and they also give another ballats but it's still the same,
yes it flickering,
i think we should use a vag-com to adjust it, and if you in melbourne i found a place called volkspower it's in burwood, the complete address can be find in the website
Hi Vw138,
Did you buy it from volkspower?
I am in sydney.
Is your headlight still flickering?
My headlight is flickering for the first 1 min...after that fine with a new ballast...turn our to be philips now...
I believed we need to adjust it via vag-com....but no 100% prove...
- You may not post replies
- You may not edit your posts
Forum Rules
