Results 11 to 20 of 26
Thread: Advanti 19"s Are On!
    Jul 2007
    Sydney - the regressing city
    Looks good
    I would stay with the same height for the front and lower the rear...
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by Mischa View Post
    i've been in VAG cars with coilovers where the ride is more comfortable than in my GT. do you speak from experience or hearsay?
    Quote Originally Posted by DubSteve View Post
    x2 do you have any experience?
    a lot of experience growing up in and around tuner cars and more recently hanging around the drift scene where coilovers are a must.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Mar 2007
    sydney
    if that was my car. id be going 60mm at the rear & 50mm at the front.
    man if your not going to lower it, might as well left it with stock wheels
    now the car just sits higher
    2004 GTI, GIAC, DOWNPIPE
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
    Feb 2008
    Townsville QLD
    Quote Originally Posted by VWEAPN View Post
    might as well left it with stock wheels now the car just sits higher
    Bigger wheels are normally fitted with lower profile tyres to maintain the original diameter / circumference as near as possible. This means that the car sits at its original height as the hub centre to road distance is the same.
    Granite Passat sedan TDI (125kw), DSG, beige leather
    Candy White Polo 6R, 66TDI, DSG, no options
    Oct 2006
    Quote Originally Posted by vanDub View Post
    incorrect
    it will still lift your car regardless of that the circular difference is.
    go to a stock passat with 18s, measure from wheel/hub centre to guard, then measure yours.. you will find its different
    ive had 16s, 17s, 18s, and 19s.. trust me ive measured them all on all the cars ive had
    Jan 2007
    Thats not really the case, if your putting 19's on the car your increasing the diameter of the wheel by 25mm, whilst reducing the tire profile in this case by 5m or 10mm in diamter, making it 15mm higher than stock.
    Same thing happened in my mk3 475mm on 14/60 vs 496mm on 16/45
    a 21mm difference in height...
    Dec 2007
    Ermington, Sydney
    I don't mean to keep this little argument thing going, but circumference calculations are available on the web (i'm looking for the link i used) and it says that my 15" wheels wrapped in 205/50 15 tyres have a size of only 5mm less than 16" wheels wrapped in 205/45 16 rubber.
    EDIT: I've just done a quick calculation on www.1010tires.com with pictures to show that there are only a few mm's in difference according to calculations on tyres. Of course there's always tyre inflations, stretch etc to consider but this is just for a guide.
    those wheels are **** hot, they fit perfectly with the rest of the car.
    1.9TDI Eibach pro xenon 6000k egr removed Chipped to 180Hp
    Apr 2008
    Rolling Diameter is CRITICAL
    Rolling diameter (and hence hence ride height) MUST remain the same, or within 5mm, otherwise the gearing of the car changes. Even the speedo / odometer will be wrong!
    Its illegal to change the rolling diameter too much. Tire places just will not do it.
    That said, it may change 5mm or so, i guess. Will 5mm make a visually significant difference?
    RIP! 2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
    Feb 2008
    Sydney, Australia
    Quote Originally Posted by 3Putt View Post
    You are correct, the ride height is exactly the same negating any *slight* difference due to the fact that a lower profile tyre will not "sag" as much or flatten on the bottom due to the lower profile. This difference will be *negligible* and not noticeable though.
    The wheels look great, mate.
    What tyre size did you end up getting? The 235/35 x 19 or the 235/40 x 19 or 245/35 x 19?
