Originally Posted by
2muchcoffeeman
Hi all,
The headlight washers switched themselves on the other night while I was on the freeway..
The result? One of the washer covers on the front bar has blown right off and there's just a sad hole where it used to be.. Good thing I was at the speed limit and on cruise control...Who knows what else might have flown off!
Sounds like time to visit for some warranty work
Seems really odd...
Take to VW and see what they can do.
When you say the headlight washers, did the windscreen washers come on at the same time also?
As with mine, the headlight washers and windscreen washer come on at the smae time and only if the headlighhts are "ON". And only if you activate the washing system via the push/pull stalk.
Keep us up to date!
