check ur fuses?
Hi, Any help with this little problem would be great. My 99 V6 Passat has just started to bring up the following warning lights.
When you start there is a noise ding ding ding (not the Seat belt one)
The tacho does not work
The ABS light stays on
The Handbrake Light Flashes
The Oil Light Flashes
These problems stay on the whole time.
The car has oil, and fluids, it drives as good as ever, I would guess that there is a problem with a relay or sensor any ideas
Thanks in advance - Moostin.
500 Series Hino - 99 V6 PASSAT Daily Driver
84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
check ur fuses?
Yep, Thanksthey all seem to be good and correct, any more ideas?
yeh, get it scanned wif FAG-COM![]()
vag-com the car to see what are the codes...
possible that the instrument cluster has died...
Thanks,
Guess I'll have to take it to a garage, does any one recommend a local one to Melb (Nth East) Thanks![]()
See this thread
He's a top guy and very experienced with dubs. Has vag-com too and located at hoppers crossing.
Or you could try volkspower in Burwood.
Thanks Neil. Do you have a Phone # for the guy @ Hoppers?
