Results 1 to 7 of 7
Thread: 90' Passat Aux air valve probs
    Jul 2005
    Melbourne, Williamstown
    How do I check the function of my auxilary air valve? I though this was the problem as the car won't start well or idle when cold. I got a different valve and it hasn't fixed the problem. Some people told me the valve must buzz when you switch the ignition on which the original one didn't do and the newer(2nd hand) one didn't either?
    Can I just check it with a multi meter or connect it up to a little 9v Bat to check it?
    Any suggestions would be great. Carl.
    mk2 GTi 16v
    Corrado G60
    Make sure the throttle closed switch is working. That's what makes the ISV operate I believe. Exactly which engine do you have? 2E 2 litre or something else.
    There is an output transistor in the ECU that has been known to blow and stop controlling the ISV.
    GAvin
    Jul 2005
    It's got a 9a engine, it could be that switch you're talking about.
    mk2 GTi 16v
    Corrado G60
    I had a 9A, all kinds of trouble with the tickover. The switch is the culprit.
    I have the Bentley for that car too in case there is any probs with diagrams etc.
    Jul 2005
    so how do I fix the switch? or do I need a new one? or worse still a new throttle body?
    mk2 GTi 16v
    Corrado G60
    Switches available seperate to the TB. The switch itself is a common or garden microswitch which I bet you could get from Jaycar or Tandy. Just need to make sure the throttle is closing properly, ie the cable isn't too tight.
    Sometimes the connection to the ECU loom gets oxidised up and a good re-rack of the connection with some contact oil fixes it.
    GAvin
    Jul 2005
    Thanks mate.
    mk2 GTi 16v
    Corrado G60
Similar Threads
  1. Volkswagen Group Australia Sales Stats (Audi, SEAT, VW, VWCV) 1991-2008
    By phaeton in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 08-11-2010, 10:52 AM
  2. Passat 2.0TDI Wagon ::Review by The Age::
    Last Post: 01-03-2007, 09:57 PM
  3. Replies: 9
    Last Post: 18-02-2007, 09:56 AM
  4. Replies: 0
    Last Post: 07-02-2007, 12:12 PM
  5. $400 long haul passat
    By 20v kit car in forum Passat (B4 & B5)
    Last Post: 09-08-2005, 10:16 PM
