There is an updated bulletin on timing belt changes . It affects the TDI range more but I think there may be a change from 120k km to 90k km for 1.8t engines
the info ive posted above is out of the manual and vw specs
Hey guys, i know this is a bit late but i have a question.
How much does it cost for a timing belt to be changed? I am looking at a few MKIV Golf GTI's with around 100k KM's on them and just want to know how much i'll be forking out.
Cheers,
Rule of thumb for belts is 90,000km or 4 years and also change tensioners,rollers water pumps and dampeners if fitted.Around $660 for 4cyl and $800 for 6cyl.Still a whole lot cheaper than pulling heads!
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
I'm sitting at around 77k atm
Will probably change it at 80k
is 80k a big cleanup/service or something for B5 passats?
Guys,
This is really bad, i feel so horrible.
My passat has 158,000 on the clock (roughly) and the timing belt has never been changed. I just checked the service history.![]()
Take it up to Dereck (Northern Beaches) or Seb (Western Suburbs) and get them to have a look.
158k's i think it would of snapped by then.
mine wasnt log in the book but found out it was changed
