Meh. I used it once just to see what it was like. Yeah, it did the job but I haven't even thought of using it since. What surprised me when I did it was once you take your foot off the brake, it felt like about a 2 second pause (I don't know exactly how long it was but it felt like an eternity when you're expecting to get thrown into the back of your seat..) before it took off.
However, I used it when it was 1500km's and in pouring rain (it almost rained non-stop from the day I picked it up to the 1500km point when I said I would give it a shot). Absolutely no noticeable wheelspin and took off like a rocket.
If you're going to take it to the strip, it'd be something you'd have to compensate for - letting the brake off a little earlier before the tree goes green.
Not quite DimMy, higher revs will lessen the chances of bogging down.
Also, not much chance of wheelspin with 4WD and 'only' 350Nm. Need more like 500Nm to get some burning rubber in the dry.
Now burning clutch, thats a different story. My guess is that 3000rpm was chosen to avoid clutch slip, and to prolong clutch / drivetrain life.
My old WRX didn't like me dropping the clutch from above about 4000rpm. There's nothing like that burning clutch smell when you stop at the next set of lights!
RIP!2007 Passat 3.2 4Motion Black Sedan | 19"s | AVC-9000 | Audi A3 Sportback 2.0TFSIQ
Should've explained myself better. I agree that there's not much chance, BUT - if you do launch from say 4500-5000rpm, you may (depending on how grippy the surface is) get a tiny about of wheelspin and then the car will regain grip and bog down. It's either that or slip the clutch to the keep the revs up OR have enough power to keep the wheels spinning a bit, which would be very difficult with a 50/50 split, if you had something like 30/70 it'd be easier. As you said, 3k was probably chosen as a balance of slip/life.
