Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 130TDI Highline Suspension too firm
    May 2010
    Bundanoon NSW
    Dealer has spent some time checking, and come up with the explanation that 'KLONK' noise is due to
    fuel sloshing in the tank. Claims nothing to do with shock absorber.
    Have agreed to run fuel level towards MINIMUM. But very find explanation hard to accept.
    Noise is more like a loose fitting boot lid for example, but only on some types of bumps!
    MY13 Passat 130TDI Sedan. Autumn Brown Metalic, Desert Beige seats. Sat nav, Rev camera, Dynaudio, 12way adj seats. No ACC Previous Golf 118 TSI with ACC given to my son
    May 2012
    Sydney NSW
    Quote Originally Posted by Cossor View Post
    Dealer has spent some time checking, and come up with the explanation that 'KLONK' noise is due to fuel sloshing in the tank. Claims nothing to do with shock absorber.
    Does this happen when you go slightly faster over a bump? Or is it the shape of the sped hump that does it? Or a bit of both?
    On a previous car, the damper/strut would 'pop'/'klonk'/clunk when I would go over a speed bump above a certain speed . . . turned out to be a dodgy damper in that case - the valve would work OK in one direction (compression) but give up under the pressure of going the other way under full load (coming off a bump where the spring is giving the wheel a big push towards the other end of travel limit/s).
    It can be very annoying when the problem is intermittent - my (admittedly frustrating) experience is that it will not 'perform on demand' when the dealer is looking at it but comes back as soon as you drive off!!
    MY12.5 B7 Passat Wagon : : TDI Highline : : Icelandic Grey : : black leather interior
    sports pack | sat-nav | panoramic glass roof | adaptive cruise control | driver/lane assist | bi-xenons/LEDs | RVC plus | auto-park | auto tailgate | tow-bar | mud-flaps | sill-protection | wood trim - ||| - Lakin plate mounts | tinted | Opti-Coat | LED reverse lights | bright white driving lights + turn lights (LEDs were too 'dim')
    Sep 2009
    sydney
    Pacific Paradise QLD
    Quote Originally Posted by nyc863 View Post
    Does it have one. The 2011 certainly doesnt Models in other countries do and that thread seems to be a USA site and they have a different model to Australia
    Erskineville, NSW
    Go down to 16" rims with 205/55r6
    Koni Yellows are traditionally very compliant on initial bump but it would be a $1000 roll of the dice.
    Is it shocks or springs that are too harsh? You could also get slightly longer springs of a slightly lesser spring rate done.
    Sees odd you couldn't test drive a car. There's the local dealer in Moss Vale and Nowra, Wollongong, Campbelltown, Liverpool, Sutherland are all <100km from you. AT dealers aren't that far away either.
    GL with it
    Feb 2013
    Wollongong NSW
    Skip Wollongong, they failed to remove the packers from a friends Gti polo
    2013 Passat tdi 130kw/380nm - Autumn Brown, Driver Assistance & Visibility Package, 12 way Power Seats, Adaptive Cruise Control, RVC, Auto Tailgate, Black Nappa.
    Full Nanolex paint, glass and wheel protection.
    May 2010
    Bundanoon NSW
    Quote Originally Posted by wind View Post
    My thoughts exactly.
    I thought by giving a demo test piece, all would be made clear. BUT service dept. has opted for what they think most logical answer.
    Reason for giving test piece was that I found problem occurred only on inside rear wheel, AND was also evident going over supermarket speed humps.
    Going over sags in road, eg, repaired potholes sagging again, no problem. Other parts of road with big undulations, so being tossed each way in driving seat, no problems.
    Problem occurs with road surface having an inch or so upwards bumps.
    Will try to obtain test drive on another Passat, or try to take sales guy with me and see what he thinks
    I do admit it is possible I am being very critical, but previous Golf did NOT make these suspension noises.
    In the meantime, waiting so can demonstrate with close to empty fuel tank.
    By the way, problem occurred twice when just leaving dealer, but no sign rest of way home (9km poor roads)
    May 2010
    Bundanoon NSW
    GL with it
    Very happy otherwise with local dealer, unfortunately however only has small stock of VW, mixed in with Mitsubishi, Holden etc.
    Went to Campbelltown for test drive and upholstery colour, and to Wollongong for appearance of Autumn Brown paint.
    Sales manager happy to give test drive of V6 when next unit arrives, but cautions V6 not very popular. So will take a while to evaluate difference.
    In the meantime local service manager will look for possibility of retro fit of ACC, but warns wiring harness unlikely to accommodate.
