Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: 130kW Passat since Jan 2013?
  1. #21
    Melbourne, VIC
    It's a rating just like take-off weight on a new model aircraft, thrust rating of a new type gas turbine, ETOPS time, bridge load ratings, maximum RPM of a diesel, etc.
    Except, of course, in aviation they have WAAAAAY higher tolerances and margins for error.
  2. #22
    Erskineville, NSW
    Quote Originally Posted by Marakai View Post
    If by higher tolerances you mean that things are over-engineered, this is not the case. If everything was over-engineered & "a bit stronger than it needs to be" then a 747 or A380 would never get off the ground & they'd need a lot less preventative maintenance (crack detection, etc). OTOH, if you mean closer tolerances, then yes, they probably do.
    They design something but they aren't quite sure just how much stress it can take in a real life situation, so they rate it conservitavly & put it into service & then use an in-service monitoring & auditing process to assess wear & failure & gradually uprate the service parameters.
  3. #23
    Oct 2012
    Anyone know what dsg box is used in the alltrack? Is it the same one as the Touareg? (since it uses the same AWD system I thought this might be the case)
    Daniel
    HIS - MY11 VW Golf R - Leather seats, Sunroof - DSG - 19" Talladegas - Black Headlights - Dynaudio - ACC - APR Stage 1 - Maniacs DSG Paddle Extension - Volant CAI -
    HERS - MY13 VW Passat Alltrack - Sports Pack - Panoramic Sunroof -
  4. #24
    Jan 2007
    South Australia
    6-speed DSG in Alltrack.
    Touareg has an 8 speed ZF made transmission.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
  5. #25
    Feb 2013
    Wollongong NSW
    Just picked up my Passat this evening and in the service manual is a computer print out that states 130kw....anyone know how to confirm this?
  6. #26
    Melbourne, VIC
    Quote Originally Posted by toto View Post
    Was it built Jan 2013 or later? That's when they updated the engine, IIRC (or was that only the 4Motions and DSGs that were updated in January while the 2wheelers and/or manuals were done before?)
  7. #27
    Apr 2011
    CarPoint have now got the details of the new model:
    Type 3C Alltrack Wagon 4dr DSG 6sp 4-Motion 2.0DT [MY13.5]
    Power: 130kW @ 4200rpm
    Torque: 380Nm @ 1750-2500rpm
  8. #28
    Feb 2013
    Wollongong NSW
    Seems to be a lotto at the moment PHA and mine came on same boat, both built Dec 12 yet his is the 125kw and mine is 130kw motor.
    Anyone buying current stock would be wise to push for greater discounts if it's the 125kw model now that the 130kw models are now in the country (albeit randomly)
    2013 Passat tdi 130kw/380nm - Autumn Brown, Driver Assistance & Visibility Package, 12 way Power Seats, Adaptive Cruise Control, RVC, Auto Tailgate, Black Nappa.
    Full Nanolex paint, glass and wheel protection.
  9. #29
    Melbourne, VIC
    Going back into the thread history on the German forums, which linked to the VW configurators there, apparently the 130 update was first applied to manual 2WD, then the DSG 2WD and finally the DSG 4WD (dunno about manual 4WD as I didn't look). The changes were phased in between November '12 and January '13.
    Have not found anything regarding when and where the upgrade was applied along split between wagons and sedans and/or production location, i.e. Emden and Mosel. Note, all wagons are made in Emden, however sedans are split between the two plants.
    So, it does seem a bit of a crapshoot.
  10. #30
    Feb 2013
    Wollongong NSW
    On the additional plus side to the extra power and torque, we had to get our insurance ammended tonight as it was insured as a MY13 125tdi (as dealer originally quoted us). After changing the details to a MY13.5 (everything else identical obviously) our premium dropped by nearly 10%. We were not expecting that, we were expecting it to jump so we were pleasantly surprised.
