Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 07 climate control issue.
    Jan 2015
    Melb
    Ok that all sounds like good info. Where is the cheapest place to buy the microcan from?
    thanks.
    Jan 2015
    Melb
    I think you are on the money with the evap temps. I found a vw technical bulletin that says they updated the evaporator temp sender from jan 2007. It says the symptoms are low or no air flow. It looks like it was a warranty item if you complained but not a recall.
    I pulled it out and had a look today and it's still got the original style sender. The updated one has a 45 degree bend and it's longer.
    If anyone is looking for it on a right hand drive car you need to remove the lower console trim in the drivers footwell.
    I think I'll still buy a microcan though because I'm sure I'll need it at some stage. Where should I get it from?
    thanks.
    Albany, WA
    Jan 2015
    Melb
    Thanks for that. So I should get it direct from the states and not from a local distributor?
    Albany, WA
    That is the Micro-CAN you wanted to know about. First read up to check if it suits your car.
    Although I was interested in getting one earlier, I am not so sure about it at the moment. The research I did led me to believe the best version is VCDS
    https://www.google.com.au/webhp?sour...ble+volkswagen
    I am sure others who have more info than me will be around to help you out soon.
