Results 1 to 10 of 17
Thread: 07/08 Passat Problems
    Oct 2011
    Hi all
    I am looking at purchaing a 07/08 tdi passat
    and after reading a number of threads I am concerned at some of the faults that are popping up and the cost of repairs.
    Most of the cars I am looking at have close to 100000kms or more on the clock. Most of the issues discussed here seem to pop up well before the cars have reached this number of kms
    is there anything i need to look out for after the 100000km mark apart from the timing belt
    I do less than 15000kms a year. and i dont turn cars over oftern so i would be looking atleast a 5 to 8 years before purchaisng again
    any help would be appreciated
    Twiggy
    Dec 2008
    Sydney/Canberra
    Servicing is quite pricey every 60,000klms. The timing belt is around $400 for the complete kit, with around 4 hours labour.
    Other common problems are mostly injectors (7 year warranty on these now), electronic parking brake switches, and electronic steering column locks.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Oct 2011
    thanks for the info
    is the 7 year warranty from the build date of the car and is it transferable to the next owner?
    Twiggy
    Dec 2007
    Quote Originally Posted by Umai Naa!! View Post
    labour.
    Going to a good independent VW specialist mechanic will get you cheaper andpotentially better servicing.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by twiggy View Post
    thanks for the info
    Twiggy
    On the injectors themselves, I believe. If they've been replaced, the warranty starts over on them.
    Quote Originally Posted by Passatwind View Post
    Opinions and experiances tend to vary on that one!
    Being dealership-based myself, I've seen the good, bad, and the ugly from both.
    '01 Beetle 2.0
    Cairns
    the pump injector (pumpe duese) units tend to let go one most of the 2.0 TDI ones...they about a grand each.
    plus the wiring loom for the units itself which is about 260 dollars I believe, that needs to be replaced, cause its the one causing the mess
    the hand brake switch also causes some headaches sometimes...cant remember the price
    the 125kw 2.0TDI also tends to suffers from a loss of power which is fixed by a software update for ur engine ecu... it does not cure the lack of power tho...
    i probably missed a lot, but these are the ones I had to deal with the most.
    Regards
    May 2011
    Gold Coast
    Pretty sure it's 7yrs warranty from new not from when replaced.
    Nov 2008
    QLD
    Quote Originally Posted by VolksAudi View Post
    so it is fixed by a software update for ur engine ecu, or it does not cure it? I'm confused
    Cairns
    Quote Originally Posted by clip View Post
    Yeah customers are not happy about it, only the 125 are affected somehow, and after update its not really better
    Oct 2011
    Thanks for the info. Are these issuses surrounding the diesel engine more than the actual model ie passat or jetta
    Twiggy
    Sent from my GT-I9000 using Tapatalk
