Results 1 to 10 of 18
Thread: SItes to buy Tie rod ends
    Aug 2006
    What kind of websites from the US that ships cheap and sells tie rod ends.. need to replace mine.
    or can i get them cheap locally.
    Dec 2006
    What did you do to have to replace it?
    -DIDZ
    Point Cook, Vic
    you only need to drive your car to need to replace them. They dont seem to last that long on my vr6.
    I think last time i got some they were about $50 each from euro car parts. No idea if thats a good or bad price. But probly not worth importing unless you have other stuff u want to order at the same time
    Sleepy Guest
    Germanautoparts.com i always use this site as they only charge you the actual shipping price not some made up one!! (got my new discs from here)
    Tie rod end, outer. Original design with rubber isolator in body. Fits both left and right sides $36.45
    Tie rod end, outer, full steel version. ***Improved design with solid metal body and larger 27mm ball joint (original has 22mm ball joint).*** New design eliminates the rubber isolator, is more stable and has higher load bearing capacity. Front, fits both left and right sides. $45.20
    Aug 2006
    thnx guys..
    do they make sqeeeking noises badly wen they r gone? like braking and goin over bumps
    Oct 2006
    Not usually, play in a tie rod usually means steering wheel shudder at higher speeds. If u chock up a wheel and grab it at 9 and 3 oclock and 12 and 6 oclock and try and move it, a bad tie rod will have excessive play in it.
    I would try local suspension shops first before going US as they are common thing to replace and as such shouldnt be too expensive if it is indeed worn.
    Jul 2007
    Sydney - the regressing city
    Quote Originally Posted by 1DUB2C View Post
    thnx guys..
    does not sound like a tie rod end - more like the bushes have worn out...
    check the condition of the bushes on the lower arms - your problem could be there...
