Hi Hillbilly,
We bought a new signature model to replace our 2017 Fabia in December 2021 which we are both very happy with.
Have you attempted to isolate stop/start via VCDs by any chance ?
Thanks
So far have done the following on our new Kamiq.
Rear tails on with DRL
Module 09
Leuchte 24SL HRA 69
Leuchte func C 24 alter to Tagfahrlicht
Dimming CD 24 change to 5 Press & Hold to set the change
Leuchte 23SL HLC7
C23 alter to Tagfahrlicht
CD 23 change to 5 Press & Hold to set the change
Leuchte 20BR LA70
E 20 change to Tagfahrlicht
EF 20 change to 5 Press & Hold to set the change
Drl's off with handbrake
App on OBDEleven
Dial staging
Module 17 Dashboard
Long coding
Staging change to YES Save change DOESNT WORK On Kamiq
Dynamic High Beam Assist
Module 09 Central Electrics
Adaptations
Fernlicht Assistant
Expanded High Beam Control
Change to AFS,FLA,Fernlicht ueber AFS
Menuesteuerung Fernlichtassistent change to Present
Menuesteuerung Fernlichtassissent Werkseinstellung Change to Present
Save Changes.
Hi Hillbilly,
Thanks
Yes and you cant only way is with the cheater cable from Aliexpress, which I have but havent been game to pull the console trim apart to fit it You can have it for the $50 it cost me and I have photos on how to remove the trim and switch
Thanks. I’ll look into it. Im not too keen on adding hardware to achieve this mod at this stage.
Thanks again. Im in no hurry, I’ll look into it
It's the only way to achieve this since 2020 sometime. They killed off the software fixes.
I got the cable and installed it in my mother's Kamiq.
I have one in my 2020 GTI as well.
In our 2019 Polo I used my OBD11 to do it.
MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
MY19 AW Polo - Comfortline - DAP
It's doubtful, he wouldn't share them with me so I just did it. A while ago now so I don't remember much, but it wasn't easy, photos of the parts involved would have been helpful.
