Results 1 to 10 of 20
Thread: Electrical Mods for Kamiq
    Pacific Paradise QLD
    So far have done the following on our new Kamiq.
    Rear tails on with DRL
    Module 09
    Leuchte 24SL HRA 69
    Leuchte func C 24 alter to Tagfahrlicht
    Dimming CD 24 change to 5 Press & Hold to set the change
    Leuchte 23SL HLC7
    C23 alter to Tagfahrlicht
    CD 23 change to 5 Press & Hold to set the change
    Leuchte 20BR LA70
    E 20 change to Tagfahrlicht
    EF 20 change to 5 Press & Hold to set the change
    Drl's off with handbrake
    App on OBDEleven
    Dial staging
    Module 17 Dashboard
    Long coding
    Staging change to YES Save change DOESNT WORK On Kamiq
    Dynamic High Beam Assist
    Module 09 Central Electrics
    Adaptations
    Fernlicht Assistant
    Expanded High Beam Control
    Change to AFS,FLA,Fernlicht ueber AFS
    Menuesteuerung Fernlichtassistent change to Present
    Menuesteuerung Fernlichtassissent Werkseinstellung Change to Present
    Save Changes.
    Jun 2022
    Hi Hillbilly,
    We bought a new signature model to replace our 2017 Fabia in December 2021 which we are both very happy with.
    Have you attempted to isolate stop/start via VCDs by any chance ?
    Thanks
    Yes and you cant only way is with the cheater cable from Aliexpress, which I have but havent been game to pull the console trim apart to fit it You can have it for the $50 it cost me and I have photos on how to remove the trim and switch
    Jun 2022
    Thanks. I’ll look into it. Im not too keen on adding hardware to achieve this mod at this stage.
    Quote Originally Posted by Jacs8 View Post
    Its only a cable that you attach to the switch and to the connector you pull off the switch and it enables it to be turned of all the time or back to normal as you want. Its just bloody hard to get the trim off so you c
    an pull the bank of switches out to insert it.
    Jun 2022
    Thanks again. Im in no hurry, I’ll look into it
    May 2020
    Canberra
    It's the only way to achieve this since 2020 sometime. They killed off the software fixes.
    I got the cable and installed it in my mother's Kamiq.
    I have one in my 2020 GTI as well.
    In our 2019 Polo I used my OBD11 to do it.
    MY20 MK7.5 Golf GTI - Tornado Red - LP/S&SP
    MY19 AW Polo - Comfortline - DAP
    Quote Originally Posted by genebaby View Post
    So how hard did you have to pull the trim to get it off I am reluctant to pull too hard even though a Russian guy sent me photos of him doing it
    Jun 2022
    Hi, any chance of sharing the photos for removal of console trim ?
    Thanks
    May 2020
    Canberra
    It's doubtful, he wouldn't share them with me so I just did it. A while ago now so I don't remember much, but it wasn't easy, photos of the parts involved would have been helpful.
