Quote:
Originally Posted by
Jacs8
Hi Hillbilly,
We bought a new signature model to replace our 2017 Fabia in December 2021 which we are both very happy with.
Have you attempted to isolate stop/start via VCDs by any chance ?
Thanks
Yes and its impossible as VAG have disabled the ability to do it Only way is to buy a cheater cable from ALIEXPRESS and fit that However getting the console apart to get the switch out is really hard and I gave up Consequently have the cable sitting here $30 posted
Electrical Mods for Kamiq
Jacs8
Hmm a Russian guy sent me pics and he removed the whole trim around the switches and gear lever and all so I thought it was too fragile to do that so left it. Might try it from these.
I would say it took me less than 5 minutes start to finish
That's easier than how I did it myself, but I got there.
Nothing is fragile, it's supposed to pull apart, it's just thing it with care that's the issue for our cars.
Did it yesterday and all back together but buggared if I can get it to work I bought the cable about 2 years ago and havent got the instructions. Have tried others pinched off AliExpress but cant get it to do what the horrible instructions say. Also had a bit of a hard time getting the cable down into the trim far enough to get switches back in place
genebaby
It's doubtful, he wouldn't share them with me so I just did it. A while ago now so I don't remember much, but it wasn't easy, photos of the parts involved would have been helpful.
Wasnt I wouldnt I couldnt find them and have been busy.
Shouldn’t need instructions, only plugs in one way. Once fitted the state of stop/start button remains as is until you press it again, regardless of how many times the car is started.
Jacs8
Mine doesnt. It hasnt changed anything and if i press it and it says deactivated in the dash then turn car off and its back to normal again Had instructions on how to get it to different states and have 2 versions but neither seem to work as written
I can only guess that you may have purchased a faulty one
