Results 1 to 5 of 5
Thread: T-cross mods
    Nov 2017
    Townsville
    T-cross mods
    Hi everyone,
    I bought my wife a R-Line T-cross for Christmas last year. Like the car so far.
    I am looking to start doing some mods.
    Looking at making a turbo back exhaust and intake piping and moving the airbox off the top of the motor. Maybe a front mount and piping depending on how I can work around the current setup.
    Then a tune.
    Has anyone started moding theirs?
    Nov 2007
    There are mods available for the 1.0TSI that is in your T-Cross already.
    A turbo inlet pipe (TIP) is already available, as is a cold air intake. Front mount unlikely possible due to the limited space in front, as evidenced by the integrate intercooler in the manifold. It is very unlikely you will be able to bypass that as I do not know of any replacement inlet manifolds (with out the IC) for the 1.0TSI.
    A tune is already available and Stg 1 will net you 110kw.
    Link to the tune and intake bits Products Archive - Harding Performance
    Aftermarket downpipe (DP) from the Up 1.0TSI will likely fit (see Miltek), but no cat back as of yet that I could see.
    As an FYI, you don't need to do anything to get the Stg 1 tune. The intake and DP will increase the power slightly beyond what Stg1 will give you though.
    Nov 2017
    Townsville
    Thanks mate they look good.
    I've had a search couldnt find much. See how I go.
    Nov 2007
    Front mount unlikely possible due to the limited space in front, as evidenced by the integrate intercooler in the manifold. It is very unlikely you will be able to bypass that as I do not know of any replacement inlet manifolds (without the IC) for the 1.0TSI.
    Been thinking about this, you could try using an Up! inlet manifold. It bolts straight up to the 1.0TSI head and it does not have the integrated intercooler.
    I have a spare if you want to have a go at it. In exchange (once you get it working), I'll take your manifold
    Keep in mind though, that this mod would be very noticeable to VW and may lead to warranty issues.
    Nov 2017
    Townsville
    That's an idea.
    I'll have to get under there and have a proper look I hadn't looked at that yet.
    Might even make a new inlet manifold. See what's involved.
    Is there any reason why your couldn't leave the manifold the way it is and run an intercooler as well. Going to have to get under and have a good look at this thing. Might start with stage 1 and exhaust and inlet pipe move the airbox off the top of the engine and go from there.
