Results 1 to 10 of 10
Thread: T-Roc City Life - 12 Hour Clock & Reverse Dipping Passenger Side Mirror
    Nov 2023
    I recently took delivery of a T-Roc City Life. The salesperson said the car did not have a dipping passenger side mirror when reversing and also said the clock was only a 24 hour clock.
    A quick review of the manual and you can in fact program the passenger side mirror to dip when you reverse so you can avoid gutter rash. As for the clock you need to go into the setup wizard to find the option of a 12 hour clock. This option appears nowhere else, so easy to think you can't change to a 12 hour clock.
    Pacific Paradise QLD
    Clocks are settable when you set the time as to 12 or 24 hour. Dipping mirror probably only comes on Premium models and my Kamiq LE doesnt have one and it was top model in 21. Just be aware you can only see the rear of the car and barely see rear wheels. I had one in a Tiguan and it was Ok but nothing special. What did you do in previous cars????
    Mar 2024
    Darwin NT
    On my R I can see all the way down to the ground including a good view of the rear wheel but you have to set this up to be able to do this when setting it up.
    Quote Originally Posted by HORSPWR View Post
    Yes you probably can but on lesser models it isnt lowerable in reverse and I could probably have tried to get it lower On the Tig but didnt really need it to reverse park
    Mar 2017
    Perth, WA.
    Sorry for being a lazy arse (i had to ask the same question for my Tiguan RLine), but where is the activation for the passenger side, dipping rearview mirror when reversing?
    Back in the VW world with a 2023 T Roc R, Silver with black roof.
    Nov 2007
    Quote Originally Posted by colinmc400 View Post
    1. Make sure the mirror adjustment button (on the door) is set to L.
    2. When the car is in reverse, adjust the mirror to suit you.
    After this, every time you select reverse, the mirror will drop as set in step 2 above. Works 100% on my T-Roc R
    Mar 2017
    Perth, WA.
    Cheers, will give that a crack later.
    Yep as long as you leave the knob in L From what I remember
    Mar 2017
    Perth, WA.
    I did finally get this working, but even one of the dealer service guys didn't know the little tip required. It looks like you actually have to start reversing for it to dip and it only comes back up to the normal position, when you actually start moving forwards. It will not dip or return if you stay stationary.
    Well that would be logical wouldnt it Putting it in reverse drops it and when you start moving forward it lifts it. The sensors that do it are probably enabled by the engagement and movement of the appropriate gear. Has always worked ok in the cars Ive had with it . Also from what I remember that book in the glovebox tells you how to work it
