Results 1 to 10 of 16
Thread: Service Schedule
    Jul 2010
    Qld
    Service Schedule
    Does anyone have a service schedule for the T-Roc?
    I know it is a 12 month/15,000km service interval but I can't find anything on what actually gets done at each service. This is the first time I've ever seen a car that doesn't come with a service booklet. The dealer service department just said to google it. I tried that and got no results.
    If you're going to pre-pay for the dealer service plan it would be good to know what you're actually paying for.
    The 3-year plan is $1,300 and the 5-year plan which would probably take the car to the end of the warranty is $2,100. That latter plan supposedly saves almost $700 of the cost of getting those services as regular "assured services".
    If you dig a hole and it is in the wrong place, digging it deeper isn't going to help.
    Jul 2020
    Maroochydore Queensland
    Hi Banzai, I have a new/ish T-Cross and T-Cross and T-Roc are the first vehicles without a service book. Others are following. My dealer was unaware of the issue until raised by me. All services will be recorded digitally and stored. You can request that PDF records be emailed to you for your own digital and/or paper record. This doesn't answer your question and one that I didn't ask. I assume that it will cover all the normal dot points but will be predominantly oil change and checklist with periodic pollen filters, air filter. It's a bit hard, after keeping well maintained books for years to be kept in the dark, but that seems to be the new paradigm. Cheers
    Erskineville, NSW
    Quote Originally Posted by Suncoaster View Post
    Other vehicles in the VW group have been digital for 2-3 years. It's a crap system as non-dealership workshops can't record your service.
    Jump onto VW Sutherland and the service items are listed: Volkswagen Service Sutherland | Sutherland Volkswagen
    Select the vehicle and book a service. Then you can select the service interval and click on the link to "see package details". It itemises all the inspections and maintenance items.
    12month / 15,000km - engine oil/filter change, brake fluid
    24month / 30,000km - engine oil/filter change, brake fluid, pollen filter
    36month / 45,000km - engine oil/filter change, brake fluid, air filter
    48month / 60,000km - engine oil/filter change, brake fluid, pollen filter, spark plugs, fuel filter
    60month / 75,000km - engine oil/filter change, brake fluid
    72month / 90,000km - engine oil/filter change, pollen filter, air filter
    84month / 105,000km - engine oil/filter change, brake fluid
    96month / 120,000km - engine oil/filter change, brake fluid, pollen filter, spark plugs, fuel filter
    Additional items:
    Haldex Oil - every 3 years
    Renew Toothed Belt, Tensioner and Roller - every 7 years or 105,000km
    Jul 2010
    Qld
    Thanks Tigger73
    Quote Originally Posted by Banzai View Post
    Thanks Tigger73
    No problem. It's a pretty standard service schedule for VW.
    The only thing it doesn't show is the DSG service interval which I think is 4 years / 60,000km but it's not listed.
    Dec 2020
    Bracken Ridge, Qld
    Also questioned the Service Book not being in the wallet with the Owner's Manual when I picked up the T-ROC and was told VW had gone to VSR (Virtual Service Record) ..... Rego No will bring up the VIN and so no matter which dealer you go to for service they can see your record and what's been done or not done.
    2016 (MY17) VW Golf GTI 40 Years 6 Speed Manual SOLD
    2020 VW T-ROC 140TSI Sport
    Pacific Paradise QLD
    With a little googling I found this As with the TIguan the 48 month one includes a DSG service hence the price
    Service Pricing Guide | Volkswagen Australia
    Dec 2020
    Bracken Ridge, Qld
    Would explain why the fixed service cost @ 48 months is so expensive.
    Dec 2020
    Bracken Ridge, Qld
    Took out the 5 year plan - saved $696 (what VW state) ...... bit of an issue with getting the paperwork through via email which took 6 weeks - my email the fault apparently which no one else has a trouble with - well try this gmail = got it in a couple of hours.
    Anyway checked the 2021 fixed service costs and they had all gone up for the 5 years and so now an additional $196.00 has been saved and expect more from 2022 on.
    Only issue is VW must be the only service unit who do NOT do a wheel rotation and balance unless you ask for it = so dumb
