Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: OBD11 modifications
    Jun 2007
    Sydney, Australia
    OBD11 modifications
    Confirmed changes using OBD11 on a MY21 T-ROC with MIB3:
    Change clock display from 24 hour format to am/pm
    Adaptation
    Control unit: 17 Dashboard
    Values:
    Time:
    Old value: 24h
    New value: 12h AM_PM
    Changing setting for lane departure warning
    Adaptation
    Control unit: A5 Driver Assistance
    Name: Warning intensity, lane depart. warning
    Values:
    Old value: Medium
    New value: Selection via menu
    Remembing driver's seat heat setting
    Adaptation
    Control unit: 08 Air Conditioning
    Name: Retention of driver's seat heater level
    Values:
    Old value: active for 10 minutes
    New value: active
    Changing setting for adaptive lane guidance
    Long coding
    Values:
    Point_of_intervention:
    Old value: late
    New value: early (setting via menu)
    Display AC blower speed
    Long coding
    Values:
    Blower display in auto operation:
    Old value: Not activated
    New value: activated
    Prevent ACC slowing down when passing vehicle in right lane
    Long coding
    Control unit: 13 Adaptive Cruise Control
    Values:
    Overtaking_right_prevention:
    Old value: activated
    New value: Deactivated
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Mar 2017
    Tasmania
    Rear wiper dwell/intermittent cycle time (this worked successfully on my 2021 140 sport):
    Rear Wiper Delay
    09 - Central Electrics
    Adaptations
    Security Code 31347
    Rear Wiper
    Select Einzelansteuerung Heckintervallwischen:
    Change to: Unabhaengig_der_Fahrzeuggeschwindigkeit (stock = "not active")
    Select Einzelansteuerung Heckintervallwischen Zeitintervall 1
    Change to: 15s (stock = 7s)
    Jun 2007
    Sydney, Australia
    Traffic sign recognition - MIB3
    This will work for Australian models.
    Coding is by OBD11.
    You will need to open the bonnet for this to apply.
    To display the speed limit on the driver's display. This coding will use road sign detection mode not fusion mode. The front camera will only read speed limits not use any data with speed limits loaded within the maps.
    OBD11 modifications-traffic-sign-displayed-jpg
    A5-Driver Assistance
    Click on Long coding
    Press the button on the top right that shows a '0' and '1' to see it Bytes mode; Each Byte has 8 bits (from 0 to 7 included)
    Press the right arrow down until you reach Byte 16
    Inside Byte 16 activate bit 4 and do not modify the rest
    Press the Validate button
    Exit Module A5 and enter Module 5F
    Click on Adaptation
    Search for Vehicle Menu Operation
    Enter menu_display_road_sign_identification and change to Active
    Enter menu_display_road_sign_identification_over_thresho ld_high and change to Active
    Go back to Adaptation and look for Vehicle Function List BAP
    Enter traffic_sign_recognition_0x21 and change to Active
    Enter traffic_sign_recognition_0x21_msg_bus and change to ' Data Bus Infotainment'
    Exit Module 5F and enter Module 17
    Click on Long Coding
    Down, press the right arrow until you reach Byte 5
    Inside Byte 5 activate bit 2 and do not modify the rest
    Click on Adaptation
    Road sign detection fusion mode
    Change to "Road sign detection" (Road sign fusion)
    Security Key: 20103
    Restart the Infotainment by pressing and holding the power button between 10s to 15s and release.
    In the settings of the driving assistants, the option 'Dynamic Road Sign Display' should appear. Tick "Show in instrument cluster" and "Speed warning" to "Visual".
    There is also an option to warn when exceeding the speed.
    Note: You will now get a warning which indicates that signal recognition is limited. This warning will appear for a few seconds in the instrument cluster after you drive off. This message is only informative and does not produce any problem, error or failure. The recognition of signals will work normally but limited because it is not using the data from the maps.
    School zones at 40km/h will be detected as 40km regardless of the main speed limit and will show as a speed warning when you pass them.
    NOTE:
    This coding was developed using the 3Q0 front camera (A5 driver assistance).
    If you have a 2Q0 front camera the final drivers assistance part to change to "Road sign detection fusion mode" is not available.
    Flipper Dog
    Pacific Paradise QLD
    Be interesting to see if this will work in our Kamiq when it arrives.
    Is almost identical to what you do in a TIguan and Golf Mk7
    I have found that it is best to put the security code in first before coding or it wont let you do it (sometimes)
    Feb 2018
    Hey @flipper - just picked up our Tiguan R and followed the instructions for the MIB 3 unit. Everything's works until getting to road side fusion where it is saying function not available.
    In OBDeleven also byte 5 has been renamed so no longer shows bits. However there was an option names Traffic sign recognition in the third row that I assumed to be the same as bit 2..
    I'll keep investigating to see if there is a way to change the bit
    Quote Originally Posted by Grugly View Post
    Well all that is available for my Kamiq 21 but what I want to know does it work for a 2Q camera as a lot of stuff wont as most have a 3Q camera
    Mackay QLD
    Hi there Flipper Dog
    I have a MY21 T Cross with a 2Q Valeo A5 ECU and am trying to activate Sign Assist without much luck to date. Coding in the 17 kombi and 5F MIB3 (without Nav) head unit appears to be the same at the T Roc Tiguan Golf etc. However in the A5 camera ECU instead of Byte 16 bit 4 it is a combination of codes in Byte 12 Bits 3 to 7. I have tried a number of combinations here and it still does not work.
    I am also not sure if it is a bus setting in the 5F ECU as I have seen Extended, Infotainment and Comfort options all being used but this may because different head units may have been installed. At this stage I am leaning on the Infotainment option.
    In VCDS I am able to see 3 "fusion" options in the Adaptations drop down menu which are currently set to activated, road sign detection and the numerical value of 0. Are you able to see this last setting in OBD Eleven and if so what is the value?
    Thanks
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Quote Originally Posted by Bambazonke View Post
    Thanks
    Further to my previous posts my Kamiq has roadside sign recognition from factory but I cant get it to show in the Dash, even though that is ticked in the MMI You have to change fusion to plain recognition as fusion doesnt work in our maps
    Jun 2007
    Sydney, Australia
    @Bambazonke
    Is this what you are looking for in A5 Control unit Adaptation?
    OBD11 modifications-screenshot-obdeleven-jpg
    Flipper Dog
    Quote Originally Posted by Flipper Dog View Post
    Are you replying to me or him. Ive got it sorted in both the Kamiq and the Tiguan. Difference is the Tig has a 3Q0 camera and the Kamiq has a 2Q0 which isnt able to be coded very easily, if at all it seems
