Results 31 to 36 of 36
Thread: OBD11 modifications
  1. #31
    Jan 2024
    Drummoyne, NSW
    A lot depends on which model camera you have . There is a 2Q and a 3Q. One is on the older models and works the newer one doesnt. Cant remeber which is which as I dont have the Tiguan nay more
    I am sure than I have the newer camera as Fusion mode is not even available to adjust in OBD11 via the app. I do find this it is strange that the same model car in US and EURO seems to work?
  2. #32
    Pacific Paradise QLD
    Quote Originally Posted by nova_sounds View Post
    The reason fusion mode doesnt work here is because the maps are different and dont have the info required for it to work Also our maps supposedly dont have a database of speed signs and yet in my Tig it used to change speeds at places that had historic speed signs before roads were improved and the speed restriction was removed.
    Eg if I go up from my house via one road and turn left onto another road it changes to the old speed of 60kph If I turn right and drive a k up there and do a U turn and come back it sees the new sign and gives the current limit which is 10 above the old one. Does that on the highway as well where it used to be 70 and is now 100. Weird but thats how it is.
  3. #33
    Mar 2017
    Perth, WA.
    Hello troops, just back in the VW world, having just bought a new old stock 2023 T Roc R here in Perth. Are there are any known OBD specialists here in Perth, that i can go and natter to, for things like the speed limit sign thing above? My Focus ST had that set up as std and is one thing i would like to have back on the dash asap, as well as just generally finding out what is hidden and what can be changed.
    Back in the VW world with a 2023 T Roc R, Silver with black roof.
  4. #34
    Jun 2007
    Sydney, Australia
    The Australian spec 2023 T-Roc R comes with the 2Q camera (A5 Drivers assistance), not the 3Q version.
    This camera is not capable to activate traffic sign recognition with OBD11 or VCDS.
    You could remove the nag screen - Adaptation
    Control unit: 5F Multimedia
    Values:
    hmi_initial_disclaimer:
    Old value: On
    New value: Off
    Prevention of right side overtaking - Long coding
    Control unit: 13 Adaptive Cruise Control
    Values:
    Overtaking_right_prevention:
    Old value: activated
    New value: Deactivated
    and remembering your seat heating - Adaptation
    Control unit: 08 Air Conditioning
    Name: Retention of driver's seat heater level
    Values:
    Old value: active for 10 minutes
    New value: active
    Start/stop deactivation is not possible via coding, you need a physical bypass module.
    Flipper Dog
    Now - T-Roc R, Audi Q5
  5. #35
    Nov 2007
    Quote Originally Posted by Flipper Dog View Post
    You cannot fit a physical bypass module to any T-Roc MY23 onwards. The button for Stop/Start is now part of a combo switch and there is only 1 plug for 4 buttons behind it. I have tried ....
    There are however, 2 other ways of disabling it. The 1st is physical (works and I have tested/used it), simply unplug the battery voltage monitor plug from the battery and stop/start is permanently disabled.
    OBD11 modifications-t-roc-ss-disable-2-jpgOBD11 modifications-t-roc-ss-disable-3-jpg
    Or put a Racingline OEM+ tune on the car ... SS is disabled by default and you have to press the button to enable it. I may have tested this 1 too
  6. #36
    The remove the battery monitor also stops the car from charging properly as the brain then cant see the state of charge and adjust it to suit. Has been said from way back not to do this. However others have different views on whether to do it or not. I wouldnt .
