Quote Originally Posted by fastlane View Post
how did you get ride of that carbon vinyl wrapped c pillar? Heat gun and elbow grease?
Start from the lower inside corner nearest to the passenger doors.
I used my thumb nail to lift a small section up to allow me to grip the decal and it was able to slowly peel away.
If you encounter any sticking use some WD40 and spray under the decal.
When you get to the upper chrome/black C pillar strip the wrap is tucked under the rubber seal of that strip. You need to carefully pull it out .
I didn't need a heat gun or have the car sit in the sun. No need for fishing line either. If the vinyl starts to tear slow down but keep a good grip and it should come away.
There was some minor adhesive residue left over which came off with a strong APC.
