Genuine sump plugs are about $4 from the dealer.
Hi all, I'm after a sump plug and / or a complete sump to suit a mk3 golf CL.
Past - '95 VW Golf MK3 VR6
Grab the low-profile N0160276 one, if you keep knocking the corners off it. Just uses a 6mm Allen key to undo, instead of trying to deal with the last mechanic's rounded-off mess.
You'll need a 14mm ID alu/copper washer for it, every time you pull it out too. Genuine part number for that is N0138157.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
if its 1,8 L
I have a sump for you Andrew
german - english translations esp vw documents!!
Dismantling 95 Seat Cord'a and 73 campers and 74 dc van !!! Some Mk1 and t2 ant3 gear in my stash,,,
plug too
$20 8v 1.8L gr8 bottom for a racer
